Question about Sanyo LAMP Projector Lamp FOR PLC-SW30/SW35 PROJECTORS
Green haze projected on wall
Hi the plcsw35 projects a green haze when connected though the phono socket not tried others but seems to project okay and in correct colour and focus when pressing menu button
oh the replace lamp light is on but don't think it would be that as projects menu okay
please help
mike
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The Lcd panels were broken, you need a new one,USD120
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 06, 2015
2 Suggested Answers
SOURCE: Ive put a new lamp
I'm having a similar issue wit a Sanyo. Installed new Sanyo lamp but when you plug it in the warning indicators show that there is no lamp detected. Ballast issue? Sanyo tech support told me this is rare. I'm not all that confident about the lamp socket. it seems to be a loose fit. Can't find any info on a reset.
Posted on Dec 04, 2010
Yes my Sony KP43T75GRAY 43 in. Rear Projection TV worked beautiful before I placed it in storage for about 7 months. Now it has a slight green haze on everything. What should I do? I was told to remove the...
The DLP tv alway have problems with it convergence board problems.Tries flash focus button or manual + - convergence R,G,B colors lines alignments up.Still have the same problems,the convergence board is dead or have problems,convergence board must be fix to solved the green haze problems.
Jan 17, 2011 | Sony KP43T75GRAY 43" Rear Projection...
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
I have changed my rear projection lamp and now the picture is green can you tell me what is causing this please.
It sounds like your light engine is defective. My Projection LCD had this happen and it started with a growing blue haze, others experienced a yellow haze, I suspect yours is manifesting with a green green haze.
It is a very expensive fix, depending on the age of your set, you may find it cheaper to replace it with something new, because a light engine itself costs nearly $2000 and another few hundred to install and align, not something a do-it-yourselfer is able to do
Oct 01, 2009 | Televison & Video
Green Screen
put a fan behind it, if it works then its heat related if not then you probably need a new main board.
Aug 29, 2009 | Proscan PS52690 52" Rear Projection...
There seems to be a green haze throughout my screen. I have adjusted it and readjusted over and over with no success...can u help me? What is the problem????
I'll do my best!
Well there's a little test i need you to do, when you have that green haze on the screen selesct the menu guide and if it also shows the green haze you will need to replace the video board, and if you have na LCD tv, you will need to replace the optical block .
May 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a scart(out) to rgb phono 3 plus 2 audio when I connect I get a message ;Mode not supported&; I am trying to free up a scart socket on my tv and also improve my picture.
Hi.
I think you are A little confused.
The 5 phono connections are for component this is not compatible with scart.
You may be able to use A svhs lead if your tv & item you wish to connect have svhs sockets & then usu red & white phono for the audio.
http://dysonmanuals.llc.nu/
Mar 20, 2008 | Televison & Video
132 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
