1999 Kia Sephia Logo
Posted on Feb 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headlights My brights will turn on but my headlights won't come on.
  • Anonymous Feb 19, 2012
    Are you talking about your dims?  If so I can help you on it.
  • Kimberly demro Feb 01, 2016
    My connector has shorted out. Melted. Why
raj somaiya
Level 3:
  • Kia Master 5,370 Answers
  • Posted on Feb 19, 2012
raj somaiya
Kia Master
Level 3:
Answers
5370
Questions
0
Helped
3570508
Points
14579
For all types of car headlights repair and service issues.Click the link below and follow the troubleshooting:----All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
--------headlights flashes while start? http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
---------Headlights flickering and car hesitates to start? http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
----------Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
--------Headlight wiring diagram ? http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
---------This will help.Thanks.
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Mar 01, 2010
SOURCE: headlights & dashlights turning on & off
Daytime running light module which is located under dash (around the area of the fuses) probably has a bad solder joint inside (if you take it apart). If not could be bad connection on one of the switches (like your dimmer switch)
2002 Grand Marquis headlights won't turn off with switch, won't go out until vehicle is turned off
Might these be "driving lights"?
Cars with "driving lights" have lights that are supposed to stay on all the time the engine is running.
These lights not only look like headlights, in fact some cars even have the headlights themselves come on when the engine is running. Look as some more (several) 2002 Grand Marquis's and see if they are the same.
Be blessed.
1helpful
Car won't turn, battery good
battery voltage must be at least 12.4 volts to start. Sound horn and see if loudness is not normal, or switch on headlights and see if brightness is normal
1helpful
Have 2007 Chevy Colorado headlights won't come on
First you have to make sure the bulbs are good, if they are check out good, you need to check the fuses and switch.
_____________
New Slim hid ballast
The dimmer switch on my 1999 firebird won't change the headlights from dim to bright, or vice versa. It has a good click to it and the blue light in the dash comes on when they're supposed to
That is a common problem, the switch needs changing if the high and low beams do work, the only problem is that it's an expensive part to replace, try a local wrecking yard they should have a bunch of suitable replacements at a reduced price.
1997 Ford E350 clearance lights don't work
First check the fuse, the clearance lights are not factory in most cases and the wiring gets shorted from poor wiring. Once you replace the fuse see if the lights come on, if the fuse blows right away find the wiring to the clearance lights and disconnect them, if the short goes away it is a I said the wiring is shorted. If you don't have the owner's manual you should be able to download it at the link provided. It should be fuse #10 a 20 AMP in the interior fuse box. http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/97ecoog1e.pdf
2helpful
Headlights won't go on
Sounds like a loose connection or a bad ground wire
Won't turn over
Turn on your headlights and go check to see how bright they are or if they are on. If they are not on when the headlight switch is pulled then check to see if you have a dead battery or your cables are loose on the battery.
My headlights won't turn on, the yellow driving lights turn on but the headlamps won't. Also the lever that controls bright lights doesn't work but the turn signal and cruise control does.
First check the headlight relay by changing it with one of the same number in the fuse panel.If it checks out ok then you have a faulty headlight switch.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
