Question about Compaq Inkjet Ij300 Printer
Printer prints each line 3 times
When printing anything, my printer will currently print each each line with what amounts to 2 shadows behind it in lighter color. It makes it look fuzzy and is hard to read.
  • Anonymous Nov 02, 2007
    yup, as above.
  • Anonymous Nov 24, 2007
    none
  • 64 Answers
There are a number of possible reasons for the problem you are experiencing: 1. The printer head might need alignment - use the printer?s software to align the heads 2. Does the problem occur with different cartridges? Try with an old cartridge before opening a new one. 3. If the ink is smeared you might want to clean the printer - make sure no hair or dust balls inside.
Posted on Aug 23, 2006
  • Bob Ha
    Bob Ha Aug 23, 2006
    There is also the possibility that the printer has a mechanical malfunction and then none of the above will help
SOURCE:
While taking a print or photocopy shadow is coming on the center of the paper
My printer printing shadow behind all the letters
f you are running the printer's Full Feature Software, go into the Solution Center in the Toolbox and look for a way to clean the cartridges and / or print heads. Do it twice. It uses a bit of ink, but it will get any extra residue drifting around on the nozzles.Your printer's Webpage:
HP Photosmart C4795 All-in-One Printer
Look on the Menu (on the Printer) for the Alignment test. This may also be listed in the same area in the software section where you find the "clean cartridges" option.
General Instructions (may vary):
Align the print cartridges
The printer automatically aligns the print cartridges after a new print
cartridge is installed.
You can also align the print cartridges at other times to ensure optimal
print quality.
To align print cartridges:
1. Load Letter or A4 plain, white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Print Cartridges.
4. Click Align, and then follow the onscreen instructions.
Jun 24, 2015 | Kyocera FS-1035MFP
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Prints with a shadow behind every letter. Cleaned heads and that page prints fine. Anything through windows doesn't print properly. Reinstalled drivers - running on windows xp.
You have a fault printer cartridge. I had the same problem and bought a new one and now the shadow dissapeared. Take it back to the place you bought it and ask for another one.
Oct 15, 2009 | HP DeskJet 1220c InkJet Printer
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
Removal of border on bottom and right side of 8X10 print of color slide.
well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
May 30, 2008 | Epson RX620 All-In-One InkJet Photo...
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Kodak easyshare 5300
It sounds like you have a bad contact between the printhead and the printer. First remove the inktanks. then remove the printhead. Now re-insert the printhead and remove it - do this a few times. What this is doing is scraping off anything that is blocking the full contact between the printhead and the printer. It should only need to be re-inserted like 3-5 times. Then leave the printhead in and install the inktanks and print again. If this does not work call Kodak and request a replacement printhead (they should not charge you its not your fault this is happening) or return the unit to where you purchaced it and ask for a new one. Once you get rid of the problem you will like the printer they do print great quality photos for such a low cost ink.
Feb 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Compaq Inkjet Ij300 Printer Logo
96 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Thomas F. Schneider
Damen Wong
Damen Wong
Alun Cox
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
