Question about Mitsubishi Televison & Video
Mitsubishi hd1080 locked tv will not go on can i reset without a remote
Dont have a remote went to change channel tv went in a lock mode and now will not go on
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
A reset is only possible with an original remote----reset will not cure set not coming on---a model number would tell me more.
Posted on Feb 19, 2012
  • 927 Answers
SOURCE: Locked TV
Good day, Katie0113; I hope you solved this concern by now but if not here is the fix: To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this helped, good luck, big IRISH.
Posted on Jul 20, 2008
  • 1153 Answers
SOURCE: Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Posted on Mar 10, 2008
  • 4090 Answers
SOURCE: picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Posted on Nov 30, 2009
pabloloco
  • 2335 Answers
SOURCE: Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Posted on Apr 30, 2010
  • 1527 Answers
SOURCE: can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
Posted on May 14, 2010
How do I unlock child lock without remote when I have accidently locked it from buttons on side of tv
What model is the TV?
By depressing two side buttons, the TV will reset the child lock
Jan 27, 2015 | Televison & Video
Mitsubishi Television Model WT42311 HD1080
ok sir! you said you got snowie screen!? make sure your cable is in good condition! or can you tell me the main problem of your unit?
Oct 21, 2007 | Televison & Video
Mitsubishi wd62526 tv has a passcode on it that i dont know ;so is there a way to change it or reset it
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Press HOME to exit the menu.
Bypassing Front Button Lock If you have misplaced the remote control, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds
Aug 25, 2011 | Mitsubishi WD-62526 Projection TV
Need tv code, tv is locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
5
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
Mitsubishi CS-26201. Can't get clear image on screen
Hopefully you still have the remote.
On Remote, hold the Q.V. button down and press the number 9. That will bypass the lock
Then press the menu button on the remote - go to Advanced features, select Parental Lock - it should sho as on, hold the Q.V. button doown and press the 9 button again, and you will turn the lock off
Dec 31, 2008 | Mitsubishi CS-26201 TV
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
Locked TV
May 19, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
27inch tv serial# 27r410T
Press vol-on tv& child lock on Remote together. Press mode on Remote using channel +/- to select child lock select new pin press mode E
Aug 08, 2007 | Sharp 25VS-J250 25" TV
Televison & Video Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
