Question about Sony 7.40V,4800mAh,Li-Polymer,Replacement Laptop Battery (VGPBPL15SVGPBPS15S) for SONY VAIO VGN-P11Z/W, VAIO VGN-P13GH/W, VAIO...
P11z bios update - Sony 7.40V,4800mAh,Li-Polymer,Replacement Laptop Battery (VGPBPL15SVGPBPS15S) for SONY VAIO VGN-P11Z/W, VAIO VGN-P13GH/W, VAIO...
Motherboard BIOS update
Support For A55M P33 MSI USA Motherboard The world leader in motherboard... Use this page to download the BIOS update. At the bottom of the list is instructions on how to flash the BIOS
Sep 02, 2016 | MSI Computers & Internet
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
My sony vaiop11z do not recognize the large battery 4800 mh h
If you replaced the battery from one of the many sites that promise complete compatibility with the original OEM battery with specs that meet or exceed those of the OEM, you're on the wrong track. They don't work in my experience. Sony has a proprietary chip in their battery packs that identifies it as an "original" The battery sites state that you have to update the BIOS drivers to make it work and if you have Windows 7, it will be problematic. I've gone through this several times, and what I've had to do is do a restore to a point prior to installing the software that the battery site provided. Although I received a notice that the restore was unsuccessful after it had been run by a system restore CD that you should make; I received notice that the restore was successful after reboot. I then ordered the battery from Sony, installed it, and all is well. Best advice is to be very circumspect in getting batteries from any source that says they are brand new and are completely compatible. A place I know to go to replace bad cells is www.batteryrebuild.com or batteryrefill.com (same site). They replace the cells, leave the original chip, and the computer sees it as an 'original' Sony battery.
Dec 19, 2010 | Sony 7.40V,4800mAh,Li-Polymer,Replacement...
When biosagentplus website scanned my pc, saying my bios was unknown but it can be updated.is it true? thanks hyui
NEVER NEVER
DONT UPDATE BIOS EVER
IT WILL MORE OFTEN DAMAGE YOUR BIOS
DONT..... PLS DONT UPDATE BIOS EVER.....
NO NEED TO UPDATE BIOS FOR ANYTHING.....
THE EXISITING BIOS IS OK......
IT JUST READS YOU HARDWARE AND BOOT FILES
EVEN AFTER UPDATE IT WILL DO THE SAME....SO NO NEED
DONT UPDATE BIOS OR FOR THAT MATTER ANY FIRMWARE ON ANY HARDWARES NEEDS NO UPDATING....THEY ARE MFD TO WORK THAT WAY....THEY SHOULD REMAIN THAT WAY
DONT MAKE THE MISTAKE OF BEING ADVISED BY ANY WEBSITE THAT TELLS YOU TO UPDATE FIRMWARE / BIOS....IT'S ALL USELESS
Nov 29, 2010 | Computers & Internet
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
No update bios found for p4i45d bios 1.20
Why do you need a bios upgrade. Unless there is a specific problem you don't need to update the bios. Updating the bios and be very dangerous if you don't know much about computers. Also unless there is a specific problem with the motherboard they won't make any bios updates.
Nov 27, 2009 | Asrock P4I45D Motherboard
BIOS update
It is not necessary to update your BIOS if everything is working correctly.
Jun 29, 2009 | ASUS A8N-VM Motherboard
Sony 7.40V,4800mAh,Li-Polymer,Replacement Laptop Battery (VGPBPL15SVGPBPS15S) for SONY VAIO VGN-P11Z/W, VAIO VGN-P13GH/W, VAIO... Logo
180 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
