Question about Sewing Machines
Foot and threading for tiptronic 6230 Pfaff - Sewing Machines
  • Tanya Watford Feb 19, 2012
    Need directions on how to thread the double needle and which foot should be used with it...Thanks
  • Sewing Machines Master
  • 7,365 Answers
An all purpose foot which can straight stitch & zig zag is what I use with double needles
when using double needles,,you thread the first needle the regular way,,then you add the second spool & thread the second needle the same way as the first
Posted on Feb 20, 2012
SOURCE: threading the machine
what is the setting to hem
Posted on May 12, 2008
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
talk2ginny
  • 34 Answers
SOURCE: Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Posted on Feb 03, 2009
LILYtheLAB
  • 3 Answers
SOURCE: So I just got myself a 7570 and so far am in love
Beside the spool carrier in the top of the machine there is a hole to the right near the front, this is there to take an upright spool pin which should be in the tool box.
Posted on May 24, 2009
WonderTech
  • 268 Answers
SOURCE: i have a pfaff 2040 tiptronic and the bobbin
Here are a couple of solutions to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
Note: When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Posted on Dec 31, 2009
Re: Pfaff sewing machine, How do I use the zipper foot attachment?
It really depends on what your zipper foot looks like. There are several that can be used with the Pfaff machines.
Pfaff Zipper Foot 4
Pfaff 1067 zipper foot instruction Google Search
Jul 08, 2017 | PfaFF Sewing Machines
I am wondering if it is possible to find the plugin on the foot pedal of a Pfaff Tiptronic 2020
Probably so, however, if may be easier to find a replacement for the ailing part. You may need to search for a donor machine or a foot control that matches your machine. You can also try replacing the entire foot control with a new replacement item.
Pfaff Tiptronic 2020 Parts
If you can't find what you need, contact them directly.
Jul 03, 2017 | PfaFF Sewing Machines
Walking foot for Pfaff 2030
Not sure what your question is, but the following may be helpful:
Pfaff Tiptronic Sewing Machine with Walking Foot
There are multiple web sites and videos online that explain how to install and use a walking foot.
You can most likely find a walking foot for your machine by searching the internet for:
Make Model walking foot
or contact Sears, a sewing repair shop, or online sewing machine accessory vendor.
What is Walking Foot Sewing Tips for Beginners
How to Use Walking Foot Attachment Sewing Machine
http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx
Pfaff Sewing Feet SewingMachinesPlus com
Nov 27, 2016 | PfaFF Sewing Machines
I have a pfaff tiptronic 6230 and the thread keeps bunching up under the material when i try to sew could you tell me what the standard settings should be to do a straight stitch. I have the G button down...
Hi Kathi it soulds like your not geting the thread in the tension unit.
Try this, thread the machine all the way to the needle but not in the eye.
Lift the presser foot up and down and pull on the thread at the same time.
You should feal the thread tension when the presser foot is down and not tension when it is up.
If this is the case then try and sew, if not then its not threaded right or your machine needs adjusting.
For were the tension dial should be set, I would put it on 4-5 for straigt and 3 for satin/button hole.
Apr 04, 2011 | PfaFF Tiptronic 2030
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Dec 31, 2008 | PfaFF Tiptronic 2030
Threading the machine
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
87 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
