What is my washer's capacity?
I'm shopping for a new washer and want to compare to my existing machine. I have a Kenmore 110.92580100 purchased in 1994.
Can you tell me what the capacity/size is of my washer now, so I can shop for one of equal size? Thank you.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Able to find a spec sheet on your specific washer, but i can tell you that you have a whirlpool made kenmore washer. and at 18 yrs ago they have only gotten larger, youd be hard pressed (unles you bought a apt sized machine or a laundry center) to get a smaller capacity machine. new machines are huge in comparison to the oldies
Posted on Oct 26, 2008
My washer won't spin out at the end of the load
you should check the brushes on the motor they wear down which stops the motor spinning.you can ring a washing machine repair shop give them yr modal number and they can alder some new ones,this is what i did and my machine worked fine after that.
Mar 24, 2013 | Kenmore Washing Machines
HE Kenmore washer vibrates quite strongly on high spin, which is the Normal default for the machine. I have had it adjusted for levelling, then had to have a new machine delivered when the vibration...
most of the kenmore front loaders is that way,, if it is on a pedestal or on the second floor it makes them worse,, lg samgung electrolux all shake to a extent but kenmore is the worst
Jan 23, 2011 | Kenmore Washing Machines
Kenmore 90 series heavy duty super capacity plus quiet pak washing machine leaks a small amount water from the bottom front of washer when running a wash cycle.
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Aug 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Front door forced open and latch broken. How do you replace and install new latch?
The following link explains step-by-step how to replace a door latch on a Kenmore Elite front loader:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacements parts (if required) can be purchased from any of the following websites:
repairclinic.com
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 417 44042400 Front Load machine Sears says does not exist
YOU ARE ABSOLUTELY RIGHT. THE COMPANY SHOULD HAVE KNOWN ABOUT THIS. HERE IS MY SOLUTION: GO TO LOWE'S HARDWARE AND BUY A WASHER AND DRYER THERE. BUY THE GE BRAND. 3 YEARS AGO, WHEN OUR MAYTAG WASHER DIED, WE BOUGHT A NEW GE WASHER BEFORE MY FATHER DIED IN 2006. BUT CHECK INTO THAT. MY E MAIL ADRESS IS CoolRod41@yahoo.com IF YOU FIND THIS IMFO HELPFUL. GOOD LUCK.
RODNEY
May 17, 2009 | Kenmore 43042 Front Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
The top part of agitator dose not move every much. Washer is Kenmore Heavy Duty Serial# CF3225915
It may be time to do a little agitator maintenance. Purchase yourself a set of agitator dogs (yes, they do exist) and replace them. The following link explains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
When you take the agitator apart, inspect and clean it as well. You can purchase dogs at searspartdirect.com or repairclinic.com. Do some comparative shopping for the best price. The average cost is less than $10. I hope this helps you. Let me know if you require additional assistance.
Aug 16, 2008 | Washing Machines
Washing Machines Logo
406 people viewed this question
Top Washing Machines Experts
