Question about Labtec Audio Players & Recorders
Need Parts OR need to fix !!!
The dial for the bass is not working properly, (Tons of Static). I need to "play" with the switch to get a clear bass sound if I can get it right at all. I need a new bass control switch for this model OR find out what I can do to get the switch working properly. By my knowledge of rotary volume switches, I may be able to remove the switch and spray some cleaner on it and it "might" work. I would rather buy a new switch and make these speakers like brand new again. I've had these since 1990 and was always impressed with the sound. That was "back in the day" I agree but I want to get another 12 years out of them. Call me "frugal" (maybe stupid) but these were great speakers and are to this day. I want to keep them running if I can. I'm "old school" and can't help it, please give a clue, thanks, Gary
  • Labtec Master
  • 27,725 Answers
Open up your computer
the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Posted on Feb 22, 2012
I've got the same speakers and same problem. The volume and treble controls are 10k ohm 6 terminal potentiometers, but I don't know where to source them. I am considering removing them and soldering a couple of 5k resistors in their place. Great speakers, I have them in my garage with
My iPod.
Posted on Mar 13, 2012
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
Dean Edge 4 Bass electronics quit working
Clean the contacts on the input jack and battery jack.
Sep 06, 2017 | Dean Edge 4 Bass Guitar
Yorx turntable speed issue, And turntable is warped.
You may be experiencing Acoustic Feedback, although it doesn't really make any sense the way you describe it. Make sure the tonearm is balanced and the proper weight is dialed in on same. Does it make any difference if the volume or bass are turned down, which my point to the Acoustic Feedback.
Jul 04, 2012 | Audio Players & Recorders
Function dial works intermittently on Nikon D100
The inner mechanism may be dirty, "and a professional cleaning may fix that, or the complete dial might need to be replaced.
Apr 02, 2012 | Nikon D100 Digital Camera
Amp was playing fine. Was unhooking speaker and accidently touched the remote bass plug on amp. One speaker was still plugged in and playing while this happened. Now when I hook up the speaker all I get...
Maybe, but you would need to take it to a stereo repair shop. If a wire is burned out or a small component is blown, it can potentially be replaced. May be cheap and easy, or may be too expensive to repair for the cost of the amp.
Mar 10, 2011 | Rockford Fosgate T15001BDCP Car Amp
I have a problem adjusting bass and treble. I have too much bass when playing the TV so I adjust the bass down to get the proper balance. Then, when I play a CD, the bass is almost gone and I need to...
Figure out why the TV has so much bass. Look into its audio controls. I'd also consider attaching and listening to the TV-related audio directly and digitally through the Bose from the source(s) rather than through the TV and its questionable electronics.
Jul 15, 2010 | Bose 3 2 1 GSX System
No display and Thump and static from bass
The poor display is a known problem.. see my other posts for the cure. As for the thump..a slight one isn't uncommon... but static?- you mean crackling? from the cubes? all of them? unplug the audio leads from the head unit to the bass and see if it stops..then you can narrow it down a bit.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
My 2002 honda accord SE coupe has started to have static whenever I play any kind of music. The static is directly related to the bass. The more base, the more static. If you play hip hop or techno music,...
you need to install a filter on the power leads of the radio and the amp.  The filter in your electrical system have gone bad and your alternator is generating noise.  Have you recently done anything on the cars electrical system such as spark plugs or wires?
Mar 26, 2009 | 2002 Honda Accord
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
213 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Michael Galve
Michael Galve
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
