Question about SanDisk Sansa e250 MP3 Player
Battery will not charge
Battery does not charge even though it plugged in according to directions.
  • 149 Answers
Try to get a new battery out of the manufacturers warranty it might just be a bad battery that cant hold the charge
Posted on Oct 26, 2008
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
Camera S5200 nikon said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
give it some time to charge up maybe? Ive seen electronics, even tho plugged into a power source, wont power on until theres a bit more charge on the battery, Idk why, but thats my only suggestion
Nov 01, 2013 | Cameras
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
Why wont battery charge on laptop
A) The Battery is old, and beyond charging
B) The AC adapter (Charger) may be bad, and/or one of it's cables may be bad. If there is no one to test it with a multimeter, take it to a computer repair shop, and have it tested.
If bad suggest you look around at prices on the internet, before buying one from the repair shop. (If offered)
C) The port on the laptop, that the AC adapter (Charger) plugs into, is the DC Power Jack. (May be labeled as DC IN )
This jack may be soldered directly to the motherboard, in the laptop, or is attached to a cable which plugs into the motherboard.
For the style that is soldered directly to the motherboard, it's solder connections may have received damage.
Normal plugging in, and unplugging, may have cracked it's solder joints.
Bad connection caused by cracked solder joints, could = no power to battery. (Even though the laptop May be receiving power)
If laptop operates fine on the AC adapter, but the Battery will not charge, the problem may be a power sensor chipset, on the motherboard. May require replacement of the motherboard.
{ This chipset senses;
A) When the battery needs a Full charge, or just a trickle charge.
B) When the battery needs No charge, and power just goes to the laptop.
C) When the Battery needs a trickle charge, or full charge, and the laptop also needs power }
Regards,
joecoolvette
Jan 15, 2012 | Dell Computers & Internet
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
New battery but car will not start. Just makes a
there might be some corrosion on the plugs that hook onto your battery.
Nov 15, 2009 | 2001 Honda Accord
Unable to record
Battery may need replacing. Even though it takes a charge, it still may be too weak to operate the unit. Try using the power cord directly from charger. If it still fails, have unit serviced
Aug 02, 2008 | Sony Handycam CCD-TRV68 Camcorder
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
