Question about E-Machines eMachines Desktop PC
Power button pushed through
I pushed my power button through on my emachines someone made me a switch from the inside it has broken off how do i get another switch for my computer
  • derrickw41 Feb 19, 2009
    my button is pushed in... and now it will turn on but the tower won't
  • 149 Answers
The front panel should come off where the plastic meets the metal part of the computer tower..u may be able to take the button back out and still use it..if it doesent work when u get it out u may have to look on the motherboard on the bottom right side to see if its plugged in it is a little black rectangle it plugs into to pins if u look really close it will say like pwr sw or something like that
Posted on Oct 26, 2008
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
Compaq Presario s3310cl starts when hooking in power plug and will not shutoff using power button. Just started doing this today. Someone said to unhook everything and hold power button in for 20 seconds...
The On/Off switch is mounted inside of the Case Front Bezel. It is
very unlikely that it is broken. The problem is the front bezel
plastic switch (which is not really the switch) is more like a cap or a
knob that comes in contact with the actual switch is somehow broken.
You can remove the front bezel to see I am talking about.
Manually push On/push Off on the actual switch and your system will turn
On and Off like it should.
Jul 17, 2011 | Compaq Presario S3310CL (DF246AR#ABA) PC...
The power button completely broke off my emachine T3090 desktop. How can I get computer to start-up without this button?
You should be able To just reach in there and press it anyways. It depends what emachines uses, but normally it is a little white plastic thing that the button pushes, because it does nothing itself.
*If this answer helped you, please rate it 4 thumbs up!*
May 15, 2011 | E-Machines eMachines Desktop PC
When I try to turn the emachine on it will not do anything.
First check the power cord. make sure it is plugged in properly.
Second. see if there is a switch on power supply in the back.
Third answer these questions
Are there any noises made when you push the button ?
Are there any lights on?
Has anything been splilled inside the PC?
Apr 04, 2010 | E-Machines eMachines Desktop PC
Green light on MB but will not power up at all nothing, even if I hold the button on. Emachine T3958 about 5 years old.
first thing I would try is a new power supply. if that doesn't do it for you, it's most likely your motherboard is bad.
Feb 13, 2010 | E-Machines eMachines Desktop PC
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
Machine won't turn on . Period
Could be a bad power supply or a dead cpu. I would start by changing power supplies with one that is working if you have a spare computer with an ATX power supply. It is nolt very common but could be as simple as a defective power switch. How does the switch feel when it is pushed? Does it spring back or feel like something is broken. Most of the time when I have repaired a PC that does absouloutley nothing when the power button is pressed....dead CPU. You could also try leaving the plug disconnected for 20 minutes....maybe something in the powers supply is heating up. They will store power even when the computer is off.
Sep 13, 2009 | E-Machines eMachines Desktop PC
Ford Explorer 1998 will not start
Does it just turn over and over?
Try the inercia switch... It's a fuel pump cut off switch, located on the passanger kick pannel.
You will have to pull the carpet back. It is a black box, with a red button on top. The button should be pushed in.....
Feb 02, 2009 | 1998 Ford Explorer
Computer not turning on.
You will get the on/off switch in the market. The 3V battery that you see inside has nothing to do with the on/off switch. That battery saves your BIOS setting in CMOS when your computer is turned off.
Thanks
Oct 27, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
91 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
