My P1005 won't print from my MacBook Pro. I have twice remedied this problem and got it working only to find that the next day it won't print. Help!! Bruce Sydney Australia
  • Kirribilli Oct 26, 2008
    I tried plugging the printer directly into the wall socket and it worked at once. But it hasn't worked a 2nd time.
    MacBook Pro to HP P1005
    Bruce
    Sergeant:
  • 231 Answers
This sounds like either a software problem or that one of the cables may have a bad connection or a short in it.
Posted on Oct 26, 2008
  • 13,433 Answers
Does the printer itself work? so it would be a issue between the printer and the mac, try reinstalling the printer, if you first remove it unplug it, plug it back in to another usb and reinstall the software that should fix any communication issues.
    Master:
  • 538 Answers
Hmmm..that is a little weird..do you have the printer plugged into the wall directly or into a power strip..
  • A Womans Computer Man
    A Womans Computer Man Oct 26, 2008
    some printers demand a direct wall outlet connection..
MacBook Pro won't boot at all
It's hard to say without more information. When you say it doesn't boot, does the screen come on at all? (the first thing that shows during a boot attempt is a gray screen). If the screen does come on, what does it show? Also what year is the macbook pro?
Jun 12, 2013 | Computers & Internet
2010 13" Macbook pro will do is screen saying "Enter your system lock PIN code to unlock this Mac
The Mac is locked and has it say you need a code to open, so if you know the person who gift you the Mac ask for the code if no the only remedy is to re-load the system but you will need the the copy of the O.S.
Mar 22, 2013 | Apple MacBook Pro Notebook
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Fan won't stop
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I just installed a new color cartridge for an HP 5650 Deskjet printer but it only prints in black. I'm printing from a MacBook, OS 10.6.6
Hi, Try printing whatever you were wanting to print but click the drop down arrow right next to the printer selection tab. Then you should see a drop down menu about halfway down the menu, click it and select print settings. You should see another drop down menu called color, just click it and change it from grayscale to color.
Hope this helps, Justin
Feb 13, 2011 | Apple MB985LLA 15.4" Macbook Pro Notebook...
Hp 1005 cancel print
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 25, 2010 | HP LASERJET P1005 Printer
Epson stylus sx205 won't print on my macbook pro
Def sounds like a driver error, do you get a yellow mark next to your printer driver or is it ok?
You could try & see if there is a more recent driver from epsons website
Nov 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP laserjet P1005
Go to the printer properties, you can go from Start-->Printers and Faxes. Select the printer (it should say something like, HP LaserJet P1005 on DPR1260 ..... make a double click on there. Then select Printer -----> Properties. Then go to Ports, and DE-SELECT the box that says: Enable bydirectional compatibility. IT SHOULD BE NOT SELECTED. Then Select Apply, and then Acept. After doing this, the printer should start working.
Mar 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
26 people viewed this question
jasbo
jasbo
