Question about Bosch Dishwashers
My Bosch SMS 5012 won't turn on!!!
I emptied the filter, but it won't even turn on. I have tried using a different power source, I have tested it on all wash cycles - but no good. It also won't drain properly PLEASE HELP!!!!! daniel.rose@optusnet.com.au
5 Suggested Answers
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
  • 21 Answers
SOURCE: cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Posted on Jul 22, 2009
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Mar 17, 2013 | Bosch Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Console Won't Turn On
Well try a new ac adapter to see if it makes a difference then.
Sep 17, 2012 | Sega Genesis Console
I changed the radio in my 97 monte carlo ls by hard wiring it in. radio works but when I have it on my speed guage won't work nore does my cruz control. When its off they work fine however my anti...
Yes it does you interuptted a power supply. You basically need to get another power B+ from a different source like the battery itself. Or a empty fuse slot. Becareful even with a common ground for cruise and speed gauge.
Feb 23, 2012 | 1997 Chevrolet Monte Carlo
Hi, I tried inserting a drill bit and turning clockwise (into the Bosch Nexxt 300 washer) but the little round door won't release. I can feel the spring inside depressing when I push in the drill bit....
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Bosch Nexxt 300 Series WFMC2201UC
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
My bosch classixx 1400 express washing machine stops at spin cycle..
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 19, 2011 | Bosch Classixx WVF 240S Front Load Washer...
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
CANNOT GET DOOR TO OPEN BOSCH FRONT LOADER MODEL NUMBER WFVC5400UC. I TRIED TO UNPLUG FOR 5 MINUTES BUT NO SUCCESS.
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
**The door typically won't unlock as a result of the unit failing to drain due to an obstruction, excessive suds, also the E13 error (though it won't always show up) kind of one in the same...usually, but the pump failing can cause this as well**
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
This is the info regarding the WTVC ( vision ) series Bosch washers which differ from other prior models.
**Unplug the washer from it's power source...safety first**
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before there is a small possibility the pump itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
Regards,
Macmarkus :)
Apr 25, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Cycle doesnt stop
Jul 20, 2009 | Bosch Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
