Question about Water Heaters
I have a superflue model 6g50nvh-fv-04 with ignition failure how do i fix that
2 Suggested Answers
SOURCE: is there a reset button
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 31, 2011
Year model by serial number
So.........it's a GSW 50 gallon which you either bought in Canada or smuggled in.
Even if you have a model with a shutter damper without a fan this is NOT a Power Venter and will need standard through roof flue pipe/chimney to establish draft and vent CO and exhaust gases atmospherically AKA Natural Draft. It will NOT vent sidewall without a fan induced draft
Sep 07, 2014 | Water Heaters
I have a John Wood one pipe power vented hot water heater. The model number is Jw840nvh-fv-04. Recently I've been smelling products of combustion coming out the top of the tank where the vent is
1) Copy following link for troubleshoot resources by type of gas control valve, Venting resources, and pro water heater forum:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) This odor can indicate incomplete combustion due to lack of air supply. Get more fresh air to unit. Check that flame is clear blue color. John Wood is American/AO Smith product so air intake screen is located on bottom of unit. Use mirror and flashlight to inspect. Clean with compressed air ad or feather duster.
3) Jw840nvh is 40 gallon natural gas. Natural gas is lighter than air and rises upward, unlike propane gas that is heavier than air. Install gas detector at height correct for type of gas.
4) For safety, install CO carbon monoxide detector
5) Review product manual for correct vent lengths and diameters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 02, 2013 | Water Heaters
My 50 gal lp water heater made a slight boom sound and now when i lite it and turn on the main bunner it snuffs its self out
1) Call manufacturer with model number and serial number appearing on label on side of water heater.
http://waterheatertimer.org/Water-heater-manufacturers.html
2) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
3) Product manuals today recommend yearly service, and yearly cleaning of combustion parts, and to keep air intake clean.
If air intake becomes clogged, or combustion parts get dirty, it can slow the exit of combustion gasses, and this will soot the burner, and clog burner ports, which means slow lazy yellow flame and incomplete burning of released gas. So unburned gas is present in combustion chamber and up the flueway. The ignition of unburned gas can cause explosion of various intensity ... and the 'boom' sound you heard.
The explosion certainly overheated combustion chamber and tripped FVIR system.
4) Since each manufacturer has different FV system (flammable vapor ignition retardation system), and each manufacturer has continued to make changes over time in FV systems, the solution for tripped FV will vary by brand and age and model of water heater.
For example the intellivent gas control can be reset in some models, while other models require replacement of parts ranging from gas control valve to FV sensor to glass vial, and include possibly full replacement of water heater.
Jan 20, 2013 | Water Heaters
Rheem water heater 42vp40sf and the fvd interface failure code is flashing. how do i fix this?
Call Rheem
1-800-432-8373
TRD is flammable vapor system. Typically there is a glass bulb or fuse located in the combustion chamber.
See example image:
http://waterheatertimer.org/images/FV-TRD-glass-fuse-300.jpg
Remove the burner and look for the evidence of broken glass bulb that holds the air intake open.
Air intake is located bottom of combustion chamber, and bulb breaks causing metal plate to snap upwards and close off air supply to combustion chamber.
Rheem will have exact part number and possible instructions. Other people have wedged the air intake open to get system working again, but I do not know if that will work with your model water heater with electronic control. Working around the FV system exposes home and people to flammable vapor ignition and explosion when water heater is exposed to flammable vapors.
Example manual with illustrations.
http://waterheatertimer.org/pdf/Test-if-thermal-release-device-needs-replacement.pdf
Clean burner and pilot orifice and combustion chamber while burner parts are removed. Also clean air intake.
When burner is removed for cleaning, the access door gasket might need to be replaced.
Your product manual and/or Rheem will have that part number.
Sep 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Is there a reset button for a 6G50NVH-FV-02 hot water heater
3) Possible manual:
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
Oct 24, 2010 | Water Heaters
Superflue heater will not light
The self igniter, or thermal couple is bad.
Mar 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Superflue water heater is flashing Eco failure. What is this? What do I do?
The ECO is short for emergency cut off.
The ECO is either tripped or it went bad. You may be able to reset it or you will have to contact a rep the sells your heater to get a new part. Some are resetable and some are not... not sure which you may have. The reset ones will have a little red button to push in the center.
The next rpoblem is to figure why the ECO went or tripprd in the first place. There is probably a reason or a cause. When you refire it make surte you donot have flame roll out and proper venting. Also make sure the the thermostat works and is not letting it get too hot.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 08, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
ECO Failure
make sure your flue is clear,, and no suit is in the burner, also there are wires going to the ignitor make sure they are not touching after time for what ever reason they need to be seperated because they short out but doesn't cause any problem other then the unit not lighting
Jun 12, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
1,099 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
