Question about Pioneer SD-532HD5 53" Rear Projection Television
Pioneer SD-532HD5 I have read about other peoples problem with the tv shutting it self off. I think I need step by step instructions with pictures. Could someone help me please. This problem just started about a week ago and is now get worst. Thank you E
It is time to buy a new one,,,sorry
Posted on Jul 24, 2007
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Removing the protective screen on our Pioneer SD-532HD5
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Nov 11, 2008 | Pioneer SD-532HD5 53" Rear Projection...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Jul 26, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Off Screen Picture
There is a width problem. There could be a control inside to control this but the TV should not change so drastically. There is most likely a problem in the width circuit.. This is a high voltage circuit, and is very dangerous to tinker or experiment around inside of. Your best bet would be to call an Authorized Pioneer repair shop and have them have a look at the set. Good Luck
Jul 14, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Possesed awesome tv
the clicking noise is probably just the relay. I gyess it makes the same noise if ou turn it off manually with the remote? Does your TV have a sleep timer function? Check to see if this is enabled. You might also check the batteries. If they are old, or the battery compartment is dirty (leaking barteries etc) you might get strange behaviour. My remote lives a life of it's own, changes channels etc if the batteries are weak.
May 17, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
176 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
