Question about MGE Galaxy 3000 UPS System
Encountered "Internal Communication Fault"
We from Civil Aviation Authority of the Philippines (CAAP) Caticlan Airport had MGE Galaxy 3000 10KVA UPS System with a S/N 13299-2. It was Installed on 2003. We replaced battery, for about a year, it function normally but after, on 2008 we encountered " Internal Communication" fault alarm. We do tried again change the battery but same manifestation of trouble occur. When we tried to turn on the UPS on normal, at first it will function normally. Load protected indicate on display but after, for about 1 hour it will alarm. When Power failure/interruption occur the system could not do it function and our equipments will automatically down. We are asking for an advice/recommendation about this problem. Thank you and more power.
2 Suggested Answers
  • 14 Answers
SOURCE: We at CAAP Davao Philippines have a MGE Galaxy
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
Posted on Apr 01, 2011
Testimonial: "Thank you for your advice. We will check it out with our people. Thanks again."
Ups mge galaxy 3000 G3K
If you cannot do a reset of the internal fuse system and get it operational, then check the internal battery for continuity. If they all fail, then the AC/DC transformer has blowen.
Mar 15, 2014 | MGE UPS Galaxy 3000 UPS System
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
Temperature fault. Q5N open
pls cheak by pas slecter not normal position load on by pas temperature fault 1st cheak coling water 2nd room temp 3rd cheak temperature sencer battary breakr to batt bank side 2 wair
Jul 25, 2013 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
We at CAAP Davao Philippines have a MGE Galaxy 3000 10KVa UPS with serial no. 13299-4. It was installed last 2003. We had three times replaced its batteries over the period of years, the latest was 2008....
Apr 01, 2011 | MGE Galaxy 3000 UPS System
Rectifire internal fault
the mge galaxy 3000 ups dont start atall when switch to normal position
Apr 06, 2009 | MGE Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
Airport landing
Seems like you got everything you need. You have got the requirements and as an additional bonus you already know which programming software you want or need to use.
Should you need to know more about navigation etc. the best would be to use a good search engine and just search for keywords like aviation, navigation, airport, airstrip, and CAA also helps a lot (Civil Aviation Authority)
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
