Question about Norelco Advantage 6705 X Electric Shaver
Battery replacement I have 2 of the above units. The battery has gone bad in both of them. I have purchased generic "replacement batteries" but I am not able to figure out how to disassemble the shaver without destroying it. Please give me instruction or tell where I can find instructions.
  • Anonymous Dec 31, 2007
    The battery has gone dead in mine, as well. I haven't purchased a replacement yet, but as soon as I can figure out how to take it apart AND put it back together, I will!
    Problem Solver:
  • 5 Answers
The batteries are just 2 rechargeable Ni-Cd AA's, soldered together at one end to form a connection. I popped in two regular AA batteries, formed a connection between them, and it started spinning again!
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Posted on Dec 31, 2007
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: battery replacement
Posted on Jan 04, 2008
Cannot charge the 12 volt battery more than 10 volts. Is there a service manual available
You need to replace the battery. There is a bad cell in it. When a cell becomes bad you lose about 2 volts.
Dec 12, 2014 | Health & Beauty
Battery replacement
Jan 04, 2008 | Norelco Advantage 6705 X Electric Shaver
I bought new batteries from local store (one from Walmart and one from Meijer) but both would not work in my Cybershot DSC-H55. On powering up, I get the message "For use with compatible battery...
the camera will only work with li-ion rechargeable batteries
any alkaline battery such as energizer will not work the camera unless you have the very expensive li ion batteries
also as with all batteries that can be recharged , you may have to charge for 4 hours before use
Mar 26, 2017 | Sony DSC-H55 Digital Camera
Trying to charge my Garmin 396 with external power. The unit is showing "Battery Missing". However my battery is there.
I had this problem on an aftermarket battery I purchased last year. It worked well for several months but recently gave me the battery missing warning and would not operate the unit at all. I checked the voltage on my Garmin OEM and on the new one. The Garmin OEM, showed 8.1V on two readings, between the center and right terminals and about that between the two outer terminals. The OEM showed around 5.7 so that implied that it had some bad cells and not a broken wire. I tossed it and bought a new aftermarket unit last week. That one doesn't show a full charge and when I switched back to the Garmin battery it shows 00:00 time remaining, but still 8.1V. Maybe I should have just bought a new Garmin battery!
Jan 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
If the battery of my laptop is low i plug the ac power but still not operational
Hi Paul.
There are few possible causes for what you've described:
1. The outlet doesn't work properly - Try using a different one.
2. The power adapter is mulfunctioning or doesn't match your laptop - try using another original adapter or a generic one (make sure the Voltage is EXACTLY the same as your laptop requires and that it supplies enough Current).
3. The battery has gone bad or finished it's life-cycle - Replace the battery.
4. There's an electric problem with the power circuit on the motherboard - replace it in a service center...
Good luck and best regards,
Pelu.
Aug 18, 2010 | Computers & Internet
My charger will not charge
1) Clean the battery contacts on the radio, battery and charger with a pencil eraser.
2) Test the charger by turning the radio on while attached to the charger (do NOT transmit, as this may cause damage to the unit). If the light on the charger comes on while the radio is turned on, you have a good charger, and a bad battery.
3) If the above test detects a bad battery, replace the battery.
4) Not sure if the battery is bad? Trade the battery out of a known good unit into this one to see if it solves the problem.
Mar 10, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Seeking battery unit for a Shinco DVD player model SDP-5880
a. where did you purchase it? b. have you tried their web-site? (shinco). try getting info from your point of purchase- good luck with that! try googling brand name, model #, part# and see if there is any source for a 'generic' replacement battery. depends on how old your unit is, to some degree. shinco may be out of business!!
good luck!
Oct 08, 2009 | Televison & Video
Battery replacement
The proper matched batteries must be used. They must be matched to the charging circuits. The batteries are using solder tabs to the circuit board. They are not user changeable. The batteries are solderd on to the circuit board.
Some industrial electronics suppliers can sell the batteries, or it would be best to order them from Philips. It would be best and safest for you to send the shavers to Philips service to have them change the batteries. The battery type depends on the model and series in the particular model. If the shaver is less than about 4 years old, many of the newer series batteries should be chargeable Lithium Oxide based.
I don't know your exact model, but most of their shavers use a security Torx tool to open them. The Torx screws are usualy hidden under rubber moldings, labels, or buttons that are glued on.
The security Torx tool looks like a 6 sided star with a security pin in the center. It is not compatible to the Allen standard key.
Jerry G.
Apr 16, 2008 | Panasonic Sonic-1 ES 364 Electric Shaver
Norelco Advantage 6705 X Electric Shaver Logo
613 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
