Question about Mitsubishi WD-73735 Television
My Mitsubishi DLP HD TV auto input sensing keeps on detecting new inputs even though nothing has changed. Is there any way to stop this from happening? Or any way to disable auto input sensing?
5 Suggested Answers
  • 8457 Answers
SOURCE: I have a Mitsubishi DLP (WD-73833) and I am
Sound like ur main video board have alot prob.,must change,HDMI ports not that easy damage if used it correctly.
Posted on Nov 17, 2009
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
  • 179 Answers
SOURCE: Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Posted on Dec 29, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
Mitsubishi WD-60C9 changing inputs on its own whats the cause of that?
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Aug 18, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Hdmi inputs are not working on my mitsubishi WD65738 DLP
That TV is suppose to have automatic input detection but if it doesn't work you can press the input button on the remote and then use the arrows and enter to select the input you are trying to use.
Dec 12, 2013 | Mitsubishi WD-65738 DLP TV
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi DLP model # ws-65517, and the HDMI signal is scrambled purple, black an green lines. This is the case with my DVR and PS3, i tryed 2 different HD cables, reset button, unplugging it...
Don't you have more than one HDMI input on the back of your TV? If so, use another input and then select that input with your remote. If not, you may have to do the input replacement which you describe.
Jul 28, 2017 | Mitsubishi Televison & Video
I have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Mitsubishi 62" DLP Auto Sensing Gone???
yes - however, I recommend that u get it repaired professioinally so u don't get electrocuted
Feb 26, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-73735 Television Logo
1,035 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
