Question about Hoover Washing Machines
Hoover 700 LA keeps overflowing when filling, turn machine off at power point and water keeps running
SOURCE: Filling With Water
keeps filling with water
Posted on Dec 06, 2007
Oceti
  • 51 Answers
SOURCE: Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Posted on Jan 03, 2008
  • 1073 Answers
SOURCE: Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Posted on Apr 20, 2008
  • 1028 Answers
SOURCE: Our washing machine keeps filling
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Posted on Apr 27, 2008
Set the water level selector to a lower level. The sensor will always work if the water level is much higher than the trigger level. However, the "much higher" condition is never reached if the water is about to overflow.
Posted on Sep 14, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
My hoover washing machine will not stop fill with water it keeps overflowing can I do anything to fix it?
Does the water come in when the machine is off ? If so, the fill valve is jammed open and needs to be replaced. If the water only floods the machine when the machine is on, it is most likely the preasure tube is blocked or the preasure switch is faulty
Oct 04, 2014 | Washing Machines
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
I have a hoover 500M which we moved to a new place for my daughter. It continues filling until it overflows. I tried turning the power off while it was filling and the water stopped flowing as soon as the...
There is a sensor that detects the water level in the tub...it is usually a pressure switch that has a vacuum tube coming off it going to the level switch..it may be defective or even more simply, the vacuum hose may have come off
Jul 10, 2011 | Washing Machines
Water won't cut off when filling... Hoover Galaxy A6834
Hi Steveb6723 ,Just read your posting.Now here is a little test I need you to preform so I can tell if the problem is your water valves or your pressure switch system.Now 1st turn it to a normal cycle and only select the cold fill.Pull the knob out so it starts to fill.Now turn the machine off at the power point,Does the water stop filling straight away?If it does select hot fill and pull the knob.When it starts filling on hot water turn the power off again and see if the water
stops straight away.Please reply and tell me if the hot or cold water continued to flow when the power was off.Looking forward to your reply.
Jun 24, 2010 | Washing Machines
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
Jun 20, 2010 | Washing Machines
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Jan 03, 2008 | Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
