Question about Cameras
Bell & howell design 253 RV 8mm projector
Take up reel doesn't take up the film
5 Suggested Answers
SOURCE: How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Posted on Mar 17, 2009
SOURCE: Bell and Howell 8mm projector
http://www.ehow.com/how_5890823_thread-bell-howell-projector.html
Posted on Oct 21, 2010
kerguney
  • 577 Answers
SOURCE: I have a Bell &
Hi
most of the projectors handle 2 different versions of 8 mm films.. and ..
in accordance with this feature again most of the projectors have a switch that can run either of the version..So,your projector should have a switch to handle either of the standards.8 mm film is slower than super 8 ..You must have recorded super 8mm and now triying to play on 8 mm..If I knew your movie camera model I can tell the which one is.As far as I have checked your projector can only hande and not capable
Sorry about it.you must find another projector that can run your super 8 mm..just in case if you need a user manual pls visit the link below..
Hope this helps..if not pls ask me more..
Regards
Bell & Howell 253 & 253AR Movie Projector Manual
http://www.ebay.ca/itm/Bell-Howell-253-253AR-Movie-Projector-Manual-COPY-/250654001790?pt=US_Movie_Slide_Projectors&hash=item3a5c248a7e
Vintage Bell & Howell 253 AX 8mm Movie Projector
Circa: 1950's
Condition: Used & Operational
Size: See Description
Color: Brown-Gray Wrinkle Finish
Country of Origin: United States
Manufacturer: Bell & Howell
This great machine has a metal plate that says: 115 V. AC 60 Cycle Only 500 W Max, amps, Chicago 45, ILL, U.S.A. Projector Model 253 AX Bell & Howell. It has the Frame lever and a switch that has Lamp, Motor and Off. It works great. A metal take up movie reel comes with the projector. The unit is compact and has the metal lid with a pushbutton that opens the projector when depressed. There is a switch on the side that has the Rewind and Forward.
It measures approximately 12 inches tall by 8.5 inches wide and 8.5 inches deep. It is a heavy, well built projector and is the Iron Horse of the 8mm movie projectors of the 1950's. This projector works great and it has been serviced and ready for you to watch your old home movies.
Posted on Aug 05, 2011
  • 5 Answers
SOURCE: Bell+Howell FILMO 8mm Projector
If the backside of the arm opposite the the pin holding the reel has a screw [possibly plastic] loosen it 1/2 turn at a time. First put a film reel on the pin to check each adjustment buy putting the empty reel with your finger.
Posted on Feb 23, 2013
Hi, I'm looking for a Bell & Howell 253 AX manual. Thank you!
Bell howell autoload 8mm projector user manual english
I am unsure if this is the manual for the precise model you requested, but since it is very old, this may be the best that can be found.
Feb 18, 2018 | Bell & Howell Cameras
Came across a bell & howell 253-A projector. hooked everything up but pick up reel not spinning.
If I remember correctly those have a thin one ring type belt that powers the reel. You might check to see if it's missing, broken or off the pulley.
Oct 04, 2017 | Bell & Howell Cameras
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Dec 05, 2016 | Cameras
How do I stop my Dad's Bell & Howell projector from "skipping" while running a film, model L, design 122.
For a projector to run right, the motor has gear teeth in it that engage with the hollow points on the film itself. The motor has to turn at a steady speed with no friction or hesitation. It is possible the motor on the inside of the projector needs to be oiled or cleaned out...or rebuilt at worse.
There is also the motor that pulls the film thru the projector and winds it onto the receiving spool. Sometimes that motor is out of synch with the projector drive motor and trys to pull the film thru to fast or turns to slow and the you get that "clicking " sound when the receiving spool isn't winding the film up fast enough and the film gets dragged on by those projector teeth and make that plastic clicking sound.
Watch the film while it is running between the two reels and the projector lens. The film should be slightly taunt going into the projector and slightly taunt coming back out of the projector. If you see the film grouping up in front of the projector drive or after, then you know your spools are needing greased up or there is a drag on the motors causing things to be unsynchronized.
This is definitely a mechanical problem and you need to watch the film being fed into the projector and how it is wound up n the receiver spool to see where the fault lies.
Feb 23, 2015 | Bell & Howell Service Manual: Model 122...
Bell howell 8mm projector
is there voltage on the motor wires? if so the motor coil has a short. and needs replacing.
Dec 29, 2013 | Bell & Howell Vintage Model 253 Ax...
Nov 30, 2009 | Bell & Howell Photography
I have a Bell and Howell Model 456 Autoload Super8/Regular 8mm Projector bought in 1969. During projection, when the very end of the advancing film is no longer engaged by the rotating teeth, the film...
The Bell and Howell Model 456 Autoload was made that way ON PURPOSE. The last foot or so must be manually pulled from the projector. As described in the manual, "this safeguard has been designed to prevent the end of your film from flapping against the projector after your movie is completed."
If the entire film was going into the take up reel at the end automatically, then THAT was a defective occurence. It is not supposed to do that.
Apr 04, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Sam
Feb 23, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Cameras Logo
215 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
