Question about Gaggia Titanium Espresso Machine
Resetting the thermostat on my Gaggia Titanium
My Titanium's display is stuck on "Rinsing" /Warming Up, but the automatic rinse cycle that usually occurs when I start it up isn't happening and no water is flowing through the machine automatically on startup and the little squares aren't showing. I descaled and I ran several tanks of water (cold) through the machine. I'm not able to make any coffee because I can't get those buttons to work. The water comes out cold through the steam wand, but when I feel the top of the machine, the machine is warm. I think I have to reset something. Maybe the thermostat? How do I do that?
  • 3 Answers
SOURCE: Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Posted on May 16, 2009
  • 109 Answers
SOURCE: Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Posted on Feb 22, 2010
  • 109 Answers
SOURCE: Gaggia Titanium stuck on RINSING CYCLE
Let it rinse it may run for some time.
you will not be able to remove the brew unit as it is engaged to be rinsed.
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium that continues to Steam.
You need a new valve. Try getting the stainless steel valve assembly.
Posted on May 03, 2010
EsWorld
  • 1618 Answers
SOURCE: We have a 4 month
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Posted on Oct 06, 2010
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Titanium stuck in rinse cycle and brew unti can't be removed. Customer service is not answering the phone.
Try going into the menu and selecting rinsing. Push the enter button and use the up down arrows to chose "off". Push the enter button again to make this your selection, then the escape button. That should take it out of rinse mode.
Oct 29, 2010 | Gaggia Titanium Espresso Machine
Rinsing cicle is not stoping.Mashine not responding to any baton.How to stop Rinsing cicle and go to normal mode? Thanks Radan
If its is only the rinsing cycle at start up you can go into the menu and turn the rinsing cycle off.
If its the rinsing cycle for the descale, it has to run out of water to finish. Then reprime the machine and it will start to heat again.
Oct 28, 2010 | Gaggia Titanium Espresso Machine
Dec 26, 2009 | Gaggia Titanium Espresso Machine
Nov 17, 2008 | Gaggia Titanium Espresso Machine
Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
Aug 30, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium
John, The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." Hope this helps, Tony.
Dec 08, 2007 | Gaggia Titanium Espresso Machine
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
