Question about Dishwashers
Dishwasher cycles do not start
This is a KitcheAid Model KUDS01IJ. The control panel does light. I can select the different cleaning modes. However, when the START button is pushed, the cycle status indicator only lights next to CLEAN and nothing happens. I can puch the Cancel/Drain button and a 2 minute cycle will run (it isn't doing anything now because there is no water in the tub. My wife said the first time she did this, it actually drained the tub (ie pump got signal and worked). Now it just won't start a cycle regardless of the cleaning mode selected. I assume it is one of the electronic components, but would like to get an idea of which one(s) by name that I should consider replacing
buddymcl777
  • 67 Answers
SOURCE: Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
Posted on May 19, 2009
  • 52 Answers
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
Posted on Jul 25, 2009
jsrock516
  • 5911 Answers
SOURCE: Only thing the dishwasher will do is the cancel drain for 2 min.
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 17, 2009
  • 3247 Answers
SOURCE: my dishwasher clean light blinks only
It is linked to three possible causes which need to be looked at one by one
1. There is a block in the drain somewhere especially if you are using insinkerator / garbage disposal in the kitchen sink. Ensure drain is clear.
2. the door switch is faulty - but this is unlikely if the cancel/ drain works for 2 minutes.
3. the water heater is not working - you will need to check the heater resistance (see parts diagram) - item 1 page 5.
4. the float switch is faulty telling the dishwasher it is flooded which then should atleast run the pump - but you mentioned it does nothing. (see item 15 on page 6)
My bet is on 1 at the moment. Please rate the solution if 1 works otherwise post a comment.
Posted on Oct 19, 2010
SOURCE: Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
I had the same symptoms and the front panel was the fix
the part with the buttons on it
Posted on Oct 12, 2011
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
My dishwasher will work only on "baked on cookware" cycle. What is wrong??
Your timer or control unit whatever you want to call it has probably failed.
Dec 13, 2014 | KitchenAid Dishwashers
Status light blinking
Please do a full clean up of the machine after checking in all the connections to the mains panel.Please check this link for tips to go about:http://www.espares.co.uk/advice/dishwashers/a/3/174/cleaning-your-dishwasher.html
Mar 12, 2012 | KitchenAid KUDS01IJ - Multiple Color...
My Frigidaire dishwasher won't start. I just moved into a condo and the dishwasher worked during inspection but now it's not...wondering if it's something I just don't know about. The model number is...
Did you ever get an answer to your problem.
I've got same issue where I turn the diswasher on and nothing happens ... the time just start going down but nothing is happening?
May 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My diswasher won't work
Kitchenaids have a diagnostic service mode ... but each model can be different on how to activate. The mode is started by sequentially pressing a number of the control buttons repetitively. The particular sequence is usually listed in service technician paperwork within the dishwasher behind the low kick plate in front of the dishwasher.
Or web search "Kitchenaid KUDPO1FL S7 diagnostics" which may help you understand this whole process
Good luck on your troubleshooting
Jan 16, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
