Question about Toys
Dominator air hog won't charge.
Put brand new batteries in remote and green lite stays on.
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
Posted on Dec 02, 2010
SOURCE: I have a brand new air hog jet set and I have
does the Air Hog Jet set for beginners AH-56 white have weights on the wings and on left center? their appears to be intents where possible weights would go but their not there, is this why it won't fly since purchase, could this plane have a deffect?
Posted on Apr 16, 2011
bayyagg
  • 1672 Answers
SOURCE: Air hogs pocket copter, brand
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Posted on Aug 09, 2011
Testimonial: "I wondered if that was the problem. Well, the part about there being a defect. I had no idea about the relay whosamajiggit! I hope I can exchange it."
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
Air hogs charger blinks red then turns off
Make sure you have the switches set properly.
Dec 28, 2012 | Air Hogs Toys
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
Air hogs jet set plane won't charge
This situation happened to me too after using it like 10 times it doen't
charge anymore does anyone knw what to do and what is the neutral position for the rudder how does it have to do with charging the plane I know what the rudder is and where it is ,ut don't know how to put it into neutral position.Help???
Jan 20, 2012 | Master Heaters Air Hogs Jet Set Assortment...
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
Aug 09, 2011 | Toys
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Toys Logo
46 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
