Question about Acer Aspire 5315 Notebook
Upgrade main memory
Hi, I want to upgrade main memory of my Acer 5315 Laptop. Please provide step by step procefure.Thanks
  • Anonymous Dec 08, 2008
    I can't get the back cover off?
    Problem Solver:
  • 12 Answers
The back cover has 4 main screws after u have removed them the hole back cover is filled with latches, its a real pain to remove but u can do it. i suggest using clock work screwdrivers to lift the back cover. don't be ruff but dont just do it lightly.
good luck
Posted on Dec 09, 2008
**** me
Posted on Apr 15, 2010
  • AZXXHUS Apr 15, 2010
    ffdfggfhhgjhjhkuoihujgvcf grand pilon ********
    Scholar:
  • 191 Answers
Contact the service peson.
Posted on Oct 27, 2008
After memory upgrade it's not coming on
The RAM is either faulty or the wrong type for this laptop.
Try using the same brand as the original RAM but larger RAM size.
Oct 15, 2012 | Acer Aspire 5315 Notebook
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
Change RAM in Acer Aspire 5315
hi
nplug your laptop from the AC power source and remove the battery.
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Jun 01, 2010 | Acer Aspire 5315 Notebook
    How 2 factory reset an acer aspire 5315 laptop
    There are two basic ways to restore Acer 5315 PC Notebook to the original setting. The first method you can try to pressing the key Alt + F10 for 5 times while startup process appears on the Acer screen. Usually this way will restore the original setting automatically.
    And the next method you may need to use system restore at the first time you’ve got your Acer 5315 laptop. Here are steps to follow:
    Log on as the Administrator => Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it’s not already
    selected. Click next to continue the steps.
    There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that
    System Restore will create. Click OK.
    For the last step click next button on the Confirm Restore Point Selection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
    Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page appears. Click OK.
    Dec 30, 2009 | Acer Aspire 5315 Notebook
    Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
    I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
    Aug 20, 2009 | Acer Aspire 5315 Notebook
    Installing Acer 5315 series memory
    Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
    Jan 09, 2009 | Acer Aspire 5315 Notebook
    Ram upgrade
    Your system support only 2Gb, only 1Gb at one bank. Please Checkout http://www.memoryx.net/aspire53151.html
    you can even have your system Scan "Scan My System" from this site to give you an accurate system details.
    Hope this fix your problem!
    Dec 03, 2008 | Acer Aspire 5315 Notebook
    Acer Aspire 5315 Notebook Logo
    613 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
