Question about Siemens Refrigerators
I have a siemens frost free fridge freezer. the freezer is working but the fridge part is warm.
  • Anonymous Mar 18, 2014
    freezer working but fridge is warm
    Problem Solver:
  • 13 Answers
Check to see if the fan the blows cold air from the freezer compartment to the refrig is (a) not blocked in either the freezer or refrig, or (b) not working at all. Replacement of the fan is likely very inexpensive - cheap parts, and a possible DIY if you can use a screwdriver and read an exploded view in the on line parts manual for your model.
Posted on Oct 26, 2008
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
My frost free fridge freezer has stopped working(beko) the fan inside the freezer is consyantly on the food in the freezer has defrosted and the element at the back is usually hot and now its cold
Please checck to see if your thermostat lines are in order or if some of the connecting wires are damaged bby frost. First of all switch off the fridge and allow all frost to clear. then check for the fan circuit, the auto defrost timer circuit. Now after few hours switch on the fridge. Check to see if the compressor is running the back side is getting warm and the freezer is cooling. If not check if the compressor is pumping well or being short of gas-- get help -. If not the timer could be the culprit as after the cooling takes place the fridge does not defrost. Check this out and the fault is confirmed if your fridge works fine now. Hope you try. Good day
Aug 11, 2010 | Refrigerators
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Freezer
Not if it says manual defrost in the name.
Nov 18, 2008 | Crosley CRS40 Manual Defrost Compact...
Refrigerators Logo
797 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
Mai Lor
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
