Question about Cell Phones
Nokia 6021 cracked screen how to copy no`s from memory?
Hi has any one got one of these phones? I have cracked the screen and need to save the phone book to my sim card, which buttons in which order?
can anyone give me a step by step guide to backup my phone book to sim card
many thanks paul
  • Anonymous Nov 15, 2008
    lost phone book please help!
Nokia 6021 no signal
Posted on May 19, 2010
Missing contacts, same sim card
You didn't save them to your SIM card on your old phone.
If you take your old phone & your new phone into a store you can ask them to switch the contacts over & they should be able to do it right then in there in just a few minutes.
Jun 06, 2013 | Nokia 6021 Cellular Phone
Hi, i have a nokia 6085 with a broken screan. I want to copy contacts from cellphone to sim card. All my contacts are saved on the phone memory. How can i do it? Please help.
If you are able to see slightly then copy all the contacts from the phone memory - 250 at a time- to the SIm card and load them to another phone.
if there is no way you can see the screen then you might have to seek help to a screen to be set to to your phone ONLY to transfer the memory. You can get this help from Nokai care.
Feb 07, 2011 | Nokia 6085 Cellular Phone
The ringer on my Nokia 6021 has stopped working. vibration mode works okay and can makes calls okay. any ideas?
Every so often a Nokia 6021 Phone will cease ringing and /or vibrating when there is an incoming call, although the call is displayed fine on the screen..
The problem is caused by a software bug and I find it sad Nokia have not resolved this as it has been present for years now..
To clear the problem, Cold Boot the phone by removing then replacing the battery. However in time the fault will eventually return.
Simply switching OFF, then ON , (Warm Boot) will not clear the fault.. Good Luck - Mike
Dec 16, 2010 | Nokia 6021 Cellular Phone
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
This also maybe useful
Delete Inbox Messages Blind Nokia Broken Screen
Press left once
Press up once - Message Menu
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
Iv switched my phone on and its asking for a p u k code which i dont have can i have sum help please my phone is the nokia 6021 thnk u
take out your sim and then try my links for nokia. if it required the puk code then call to costumer care of sim card they will give you puk code without any charge. remember don't put any code to crack that puk code. it will permanent block your sim.
http://www.fixya.com/support/r4893613-unlock_code_nokia_phone
Thanks
May 19, 2010 | Nokia 6021 Cellular Phone
My N95 screen has gone black, everything is still working I just cant see anything. All my numbers are saved to the phone not the SIM, anyone got any idea how I can get them off??
Plug the AV television output cable that should have been included with the box your phone came in.
Now plug the cable into your phone and connect it to your TV.
The cable allows you to use your TV as an external screen and from there on you can save your contacts to your SIM card. You can now see and use your phone but while using your TV as a screen.
Now to copy the contacts from the phone to the SIM card, just go to Contacts > mark the contacts you want to copy to your SIM card and then press Options > then scroll down to Copy and it will allow you to copy to either SIM directory, copy to Mass memory or copy from Mass memory. Just select Copy to SIM memory and there you go !
Hope I have been of assistance to you,
Cheers :)
Feb 14, 2010 | Nokia N95 Cellular Phone
Message Contact service Nokia 6021
It sounds like it has gone into secure mode...have you entered any codes unsuccessfully into your device before it did this? If you entered any codes in before this happend and you have turned off your phone and turned back on and it's still doing the same thing..unfortunately anything you saved to your phone is a loss cause.
Feb 11, 2009 | Nokia 6021 Cellular Phone
Cell Phones Logo
294 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
