Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite H3t F21 error code - Kenmore Elite 45986 Front Load Washer
Karthik316
  • 187 Answers
SOURCE: what is f21 on the kenmore he2
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you.
pls rate my suggestion....
Posted on Jun 24, 2009
Krazytech
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
tbirdfan1
  • 3051 Answers
SOURCE: he3 elite kenmore- sUD and F21 error
Hello there"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Posted on Dec 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore HE5t f21 error code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
What does F21 mean?
The "F21" error code indicates it takes too long for water to pump out of the tub. This can be caused by using too much High Efficiency detergent or using too much of the wrong kind of detergent. This error code can also be caused by debris clogging the drain pump. Is the error continues after you clean the filter, then you will need to replace the drain pump with this new one.
Oct 20, 2012 | Kenmore Elite HE5t Washer
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
What does the code F21 mean on my washer
f21 is long drain error exceeding 8 mins check drain hose for clog or filter on washer at drain pump also remove hose from tub to pump check for blockage
May 13, 2011 | Kenmore Elite HE5t Washer
What do you do if you get an F21 code on a Kenmore Elite HE 3t steam front load washer
The F21 error code is an indication that the unit has a too long of a drain out condition. If the control call for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Mar 06, 2010 | Washing Machines
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
26 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
