Question about Refrigerators
Whirlpool Refridgerator Problem
The light went out and when we open the door there is a "rattling" noise. We replaced the bulb but it still is out and the noise continues.
Freezer side is fine.
Thanks,
Win
    President:
  • Refrigerators Master
  • 2,651 Answers
You didnt include the model, but i would assume that the "control panel lights " are also out??, and a clicking noise when the refrig door is opened??? if so you have a bad electronic control board. its located behind the refrig on the left hand side munted inside a little white box next to the compressor,
Posted on Oct 26, 2008
Electricty went out and the refridgerator did not come back on
alot of times you will have a seperate breaker in your fusebox check to see if 1 of those is triped
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ref light bulbs and noise no cooling wh-pool GS5SHA
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Strange noise when door is open, light barely flickers, LED out.
I would try replacing the bottom door cam assembly. I have also seen the actual cabinet making a popping noise during opening which is there is no cure for that.
Apr 08, 2009 | Refrigerators
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
