Question about Toastmaster Kitchen Appliances - Others
Repair manual Toastmaster MOD 1A4
One slice Toaster Toastmaster Mod 1A4 1930s
SOURCE: duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Posted on Feb 27, 2008
SOURCE: 4-slice egg & muffin toaster
RE: my post from 4/14/08
I called the 800 number and told them of my problem with the egg poacher not working after 7 months of use. To my delight, they have promised to send me a new unit!!
Posted on Apr 15, 2008
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
cactus bob
  • 267 Answers
SOURCE: Can an old Toastmaster toaster be refurbished?
there is no manual forthe repair of toasters . but the toaster you have is a common one on e bay , i dont see one right now but there have been a few over the years , and a well used one sells for around 10.00 , it may not work but its great for parts ( i collect and restore kitchen appliances) so i would take a look . you might find a cream puff for 20 .00 and put yours into retirement ..... other than e bay there not a lot of resources out there for parts . good luck ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 06, 2009
Need parts diagram for toastmaster tp409 can't find need it for part # of switch.
If you are looking for 3 position (on-off standby) switch, the part number is 33388. Visit the toastmaster site at www.middleby.com for verification and local sales office.
May 19, 2011 | Toastmaster TP409 4-Slice Toaster
I need an instruction manual for the TOV 200
http://www.hardwarestore.com/media/pdf-misc/614153.pdf
hope this is what you are looking for.
Good Luck
By the way, Toastmaster is owned by Middleby Corp.
Feb 02, 2010 | Toastmaster TOV200 Toaster Oven with...
Right side only one heating element works very hot, when should the heating element be replaced.
You can repair the other side heating element in a electrical shop or by ur self if u have the skills. Mostly the element breaks of due to food hitting at it when ejected or inserted.
Thankyou
Appreciate a good rating from you.
Aug 01, 2009 | Toastmaster TP424 4-Slice Toaster
How to remove bottom panels for cleaning Toastmaster Model T 2070
there should be a small clip or small metal piece that you move so that the doors swing open to clean.... open it over the kitchen sink tho as it makes quite a mess
Robert
Please take a moment to rate this solution thanks
Apr 16, 2009 | Toastmaster T2070W Cool Touch 4-Slice...
4 slice toaster blows fuse when toaster uses 4 burners
You will need to move it to a different outlet that is not on the circuit that you are using or just toast 2 slices at a time.
May 06, 2008 | Toastmaster 328 Toaster Oven with...
Manual
Toastmaster TUV48 manual
http://dl.owneriq.net/0/0adc711e-85ab-4238-a68a-19394579d13e.pdf
Mar 16, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Repair manual for T2020WT
Hey annaway, all toasters are repairable, but that only determines what the problem is, If you google teh type of toaster, under the following
1. www.google.ca
2. type repair manual
3. toasters
4. look for your brand name
Dec 01, 2007 | Toastmaster T2020WT 2-Slice Toaster
Toastmaster toaster
thermostat seems to have given way, needs replacement
Sep 25, 2007 | Toastmaster TP409 4-Slice Toaster
Kitchen Appliances - Others Logo
62 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
