Question about Sewing Machines
Threading my old electro hygiene model 300
Machind does not make a seam it just runs on material
4 Suggested Answers
  • 323 Answers
SOURCE: model 385 bobbin thread problems
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please do the tension assembly test as described.
Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
The bobbin should be inserted so that when you pull on the bobbin thread the bobbin turns to the left. If it turns to the right it is upside down and the thread will come out of it.
This should solve your problem unless there are scratches on your bobbin case. Check by removing the bobbin case and visually inspecting it for any groves or scratches. If you find any remove them with an emery stick and then polish it with fine steel wool.
Be sure and use a new needle when you start sewing again.
sewman7
Posted on Oct 09, 2008
  • 9 Answers
SOURCE: how to thread my 535fa
I don't even know where to start. Send me you're email address and I'll get back to you with my phone number as I don't want to post it for the world to see. I'll be able to talk you through it.
Posted on Feb 21, 2009
  • 25 Answers
SOURCE: machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
Thread bunching up ? What type thread should i use ?
Where is the thread bunching up?Make sure you have the correct thread for the needle size and material. Make sure that the thread is not old and that the needle is not bent. also, check the top tension in relation to the material being used. You could clean out the feed dogs in case there is lint jammed in there too. :)
Mar 13, 2018 | Sewing Machines
I have a joann sew essentials super stitcher model se 300 sewing machine. I followed the instructions that came with it. But when I tried to stitch, it did not even make a seam. What should I do.? It...
Check that you are installing the needle correctly, that the machine is threaded properly. Use only fresh, good quality thread--no bargain bin or old thread. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Check that the bobbin is loaded and threaded correctly. Make sure the feed dogs are up and the stitch length is set to at least #2. If you are still having problems, it could need some adjustment.
Aug 07, 2017 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
Why is the thread very easy to pullout of a seam?
Your thread tension is too loose OR you are using a too long a stitch eg Basting stitch. Try gradually tightening the upper tension first.
Sep 20, 2014 | Brother JX2517 Sewing Machine Refurbished
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
Apr 08, 2014 | Singer Inspiration 4206
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
When sewing hems and coming across a thick seam, the pressure foot seems to not allow the material to run through, keeping it stalled while the needle continues to pump into the material eventually...
I don't think you can adjust the feed pressure on this machine. I have the same machine and the same problem and my solution is the same as you've already mentioned - raise the foot and move the fabric by hand. I would do it by turning the wheel by hand until the seam is clear of the foot to prevent breaking a needle or sewing my fingers.
Feb 06, 2011 | Brother XL-2610
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
How to thread my 535fa
Feb 20, 2009 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
