Question about Maxtor Hard Drive
Onetouch 4 internal error 8211
I am getting the internal error 8211 and it appears several people are, does anyone have a solution or know if maxtor is working on it Error shows in backup of Quick book files. bonjour,
Error 8211 sur mes backups , sur n'importe quel repertoire. Je suis oblige de le renomer , cela refonctionne quelques temps , puis l'erreur revient soit sur ce meme repertoire ou un autre. c'est completement alã©atoire.
Merci pour votre aide.
  • 4 more comments
  • Anonymous Oct 27, 2008
    What is causing this error during backup and how do I resolve it?
    ERROR >>> Z:\SSCOC\SSCOC Quickbooks\SSCOC.QBW Internal Error 8211
  • grantje Oct 27, 2008
    This is the message that I receive. How do I resolve it?
  • Anonymous Nov 14, 2008
  • photocat Nov 21, 2008
    I get internal error 8211 on my back-up--imaging files, lots of others--what can I do?
  • ka_ap Dec 20, 2008
    5000 files cannot be accessed because internal error 8211
  • barbaram75 Feb 12, 2009
    I am also having the same problem with the internal error 8211. I'm not sure what dates you are talking about? It worked ok the first 2 times and then I get the error on only one quick books file. I have like 30 other quick book files that are ok.
That error occurs when the 3 Quickbooks files don't have the same date. I'm not sure how they get out of synch, but if you check the dates of the files on your Maxtor backup, you'll find they are different.
The easy solution is to delete the files from your Maxtor backup, and then immediately do another backup. Maxtor will copy the current files over and you'll be all set.
Posted on Dec 24, 2008
What's your problem?error code 0x80004004 when opening maxtor onetouch 4 external hard drive files
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
May 25, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
My C:\1386 has error 8211 on my external Maxtor 4 One Touch hardi
1st do restart ...and 2 try to do format ?? or wait me and i will share a programe it will fix ur problem
Mar 13, 2010 | Maxtor Hard Drive
Maxtor OneTouch III, USB 2.0 (500GB) not found
yes someone can get the information off the drive it will cost but yes it all depends how much you value the information thats on the drive that you would want to do this it could just be the controler card on the drive or the onetouch's controler went bad if you know someone who can open the unit up for you (maxtor is no longer anyway) have then open the case and plug it into your computer and see if it will work as a internal drive
Feb 07, 2010 | Computers & Internet
When I click on My computer, the maxtor OneTouch 4 Plus
You can try installing the drivers for the hard disk. Usually XP and vista operating systems detect the drives and install the drivers by themselves. But sometimes there are compatibility issues, which then require manual installation of drivers. I wonder what the operating system on your computer is. Please get back to me if you need further assistance.
Hope this helps :)
Oct 24, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
I'm getting "Internal Error 8211" in my Onetouch 4. Why is that?
Reasons for implant revision included documented internal device failure (46 percent), ..... (770) 205-8211... this means that there is some internal devise error which had occured during installation of some applications
Jul 30, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
HOW do i Maxtor OneTouch4 500GB External Hard Drive Format
Go to My Computer, right click on the Maxtor OneTouch harddrive, select format, check quick format, click format.
Apr 26, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Sep 16, 2008 | Maxtor Hard Drive
Backup error
It's been suggested that the software Maxtor bundles with the drive is unreliable at best. you could uninstall the software from your computer then reinstall the latest version to see if that resolves your issue. Otherwise you will be forced to use ntbackup or a 3rd party backup solution.
Jun 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Help with Maxtor onetouch 4
The Maxtor OneTouch 4 Mini is a portable hard drive, with USB interface.
What you have to do is, just connect your Maxtor OneTouch 4 MiniT to the one end of USB cable, after that insert he other end to your laptop USB por.
Wait for few moments your operating system will read your new connected portable hard drive.
After that you can find a new drive letter in your My Computer, thats for your portable disk drive.
thanks
Iqbal
Mar 10, 2008 | Computers & Internet
Maxtor Hard Drive Logo
613 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
