How to reset call for PM in Konica 7115 copier
Call for Pm is lit
  • 6 Answers
SOURCE: toshiba studio 35
switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Posted on Jul 17, 2008
Patrillica
  • 141 Answers
SOURCE: Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Posted on Apr 05, 2008
SOURCE: Cannot get the machine out of PM Maintenance mode
to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Posted on Aug 21, 2008
  • 990 Answers
SOURCE: Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Posted on Dec 15, 2008
SOURCE: HOW TO RESET CALL FOR PM IN TOSHIBA ESTUDIO 205
That's for service people only. You can ignore it until the machine fails you, or have the PM done
Posted on Feb 28, 2009
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Oct 28, 2015 | Konica Minolta bizhub Office Equipment &...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Pm reset n pm settings
Please describe your problem.PM reset not exist to Minolta CS pro 1030.
Aug 13, 2010 | Minolta EP1031/1031F CS/PRO Copier
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
Pm reset
F7-03, have a service technician clear/reset the PM count. NO reset button
Sep 03, 2009 | Panasonic Workio DP-2000P Copier
Jul 10, 2008 | Toshiba e-Studio 350 Copier
Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Feb 12, 2008 | Konica Minolta Minolta DI1610FP...
Resetting counters
Hey,
you have to go to the service menu andd under conter there is sa PM conter and life conter, and from there you have to reser transfer roller unit count.
Feb 07, 2008 | Konica Minolta bizhub C450P Laser Printer
347 people viewed this question
jasbo
jasbo
