Question about Savin Office Equipment & Supplies
SAVIN 2522, Squeal at startup, error code SC320, what is it?
Copier said to turn it off and restart, Sc320 error code. Will not go away.
SOURCE: Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Posted on Apr 30, 2009
Touch2Heaven
  • 145 Answers
SOURCE: TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Posted on Jun 19, 2009
SOURCE: Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Polygon mirror motor defective
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Posted on Sep 14, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
SOURCE: RICOH Aficio copier is giving error code SC320,
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Posted on Jun 25, 2010
Error message: sc320 can I replace it myself?
sc320 mostly defective in polygon motor you can change by your self if you know how to remove the laser unit , it easy .
Jan 06, 2011 | Ricoh Aficio 1018D Copier
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
What is code sc320
SC320 is a Polygon Mirror Motor Error/Lock
Sep 14, 2010 | Ricoh Aficio 2022 Black and White Copier
Error code 320 on startup
SC320, THE ENGINE POLIGONAL OF THE UNITY LASER DOES not TURN PROPERLY BY DAMAGE, HAVE TO CHANGE IT BY ONE NEW.
Apr 06, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I came into work today and the copier said funcional problem call for service. this machine has been working fine how can I clear that off of it? It also is showing a sign SC320 and a phone number to call....
You did not state the Make/Model but this is a Ricoh/Savin/Lanier/Gestetner failure code so I will go with that.
SC320 is a laser mirror motor failure, also referred to as the laser scanner. Most likely this code will not reset, but I would at least try powering the machine off then on to check. If not, I am sorry to say this will require a trained service technician to replace. Parts and Labor approximate cost should be around $360 depending on model.
Good Luck and sorry again to be the bearer of bad news.
Oct 23, 2009 | Office Equipment & Supplies
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Apr 30, 2009 | Office Equipment & Supplies
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Savin 2522 sc542 error code
It's a fusing warm up error. The temperature isn't reaching the right rate within 20 seconds.
There isn't a reset procedure due to safety reasons. If you replace the thermistor, it should go away.
Mar 16, 2009 | Office Equipment & Supplies
77 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
