Question about TORK Timer 1 Channel Signal Timer Dgs100
How to set a tork timer model dzs100a
Need instruction for how to set a tork timer model dzs100a
  • 3 Answers
SOURCE: NEED INSTRUCTION MANUEL FOR TORK DZS 100 TIMER
contact tork @ 888-500-4598 they can get you one and it may be available online at their web site??
Posted on Oct 23, 2009
  • 15 Answers
SOURCE: I have a Tork dzm200bp timer and do not have
http://www.tork.com/pdfs/tork/ssamoreinfo.pdf
or
http://www.tork.com/tork/productdetail.aspx
Posted on Nov 06, 2009
SOURCE: I need an instruction manual for programing a Tork
http://waterheatertimer.org/pdf/TORK.DG100.120.INSTALL&OP.pdf
Tork DG100 7-day single channel digital controller
125 Volt clock motor
NC and NO poles
Posted on Oct 13, 2010
SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Posted on Oct 15, 2010
SOURCE: My Tork 1103 timer is
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
This is probably very similar to your timer.
The Tork 1100 series is electro-mechanical timer.
Lift and rotate dial to set current time.
The trippers are black and silver.
I think the black is OFF and silver is ON
Clock motor rotates dial as time passes.
Trippers contact a lever.
Off tripper pushes lever one way.
On tripper pushes lever other way.
The manual override clicks back and forth as trippers move lever.
To check function of timer, click manual override
Common problems:
1) Clock motor is not rotating dial
2) Trippers get stuck on lever and can't move lever because timer is dirty or worn out, or clock motor is bad.
3) Trippers are worn down and won't trip the lever.
Replacement of these timers is simple
Check out the functions and problems and then answer this post and I will help more if needed
Posted on Oct 22, 2010
How do i program a tork dtu40 timer
1) Copy following link for programming manual and wiring Tork DTU40 40amp timer.
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
2) The timer mechanism is old Intermatic/Grasslin/GE discontinued model, and then newly re-minted by Tork in 2012. Timer has 1 year limited warranty against defects in workmanship. This timer is protected from surge by the reset feature, but can burn out in heavy surge event. Non-replaceable Internal rechargeable battery retains programming until timer is reset. Always reset new timer to delete trace memories.
3) This timer can be wired many different ways, and timer automatically detects voltage, so there are no dip switches to set. Timer must be wired before power is turned on. Do not spark-test across terminals.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 17, 2013 | TORK Hardware & Accessories
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
Is there an instruction booklet available?
Instructions for tork timers:
Tork makes several timers that look similar.
Link above has photos of each type with manuals.
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
I need instructions on how to set the timers on my tork electric timer for my outdoor lights ,it is put into my switch inside
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lost programming instructions, need help to reset or copy of programming manuel
Go to tork.com/tork/residentialtimers.aspx and you will see your model and then click on it for your wiring diagram
Oct 01, 2010 | TORK SS720A 7 Day In Wall Digital Timer
TORK Timer 1 Channel Signal Timer Dgs100 Logo
234 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
