Question about Dell Dimension 4600 PC Desktop
000021a error I'm getting the 0000021a error. I'm rtying to reload the OS but it doesn't recognize the CD/ROM even though the order is correct to go to it first. Tried to boot in safe mode and it's telling me I have a video driver error. Seems like a lot more than just that.
  • 1 more comment
  • andys7 Oct 27, 2008
    It's been changed. doesn't seem do make a difference. It just seems to be hung up to bot on the hard drive. Before I got the error I was having trouble with the USB's working, don't know if that will helps you, Thanks.
  • andys7 Oct 28, 2008
    Thanks for your help. That's a good list to try to see if it takes. It is just a recovery disk for XP that I have. Out of all the disk they sent me none of them are the whole windows program. I'll let you know how it comes out.
  • Pablo Csaky
    Pablo Csaky May 11, 2010
    Did you change the order boot on your bios?
    Genius:
  • 1,124 Answers
If your system does not boot, is due a:
1) Order Bios (Put Cd at the first place)
2) The CD used is not a bootable CD
Are you using a bootable cd?
Assuming your system is set to boot from the CD-ROM drive and you have an
actual XP CD as opposed to a recovery CD, boot with the XP
CD in the drive and perform a repair install as outlined below. If the
system isn't set to boot from the CD or you are not sure, you need to enter
the system's BIOS. When you boot the system, the first screen usually has
instructions that if you wish to enter set press a specific key, when you
see that, do so. Then you will have to navigate to the boot sequence, if
the CD-ROM drive is not first line, set it first in the boot sequence. Save
your settings and exit with the XP CD in the drive. The system will reboot.
When the system boots, a few screens into the process you may see a message
instructing you
to hit any key in order to boot from the CD along with a countdown. When
you see this be sure to
hit a key on the keyboard, if you miss this instruction and the system fails
to boot from the CD, it's too
late, you'll need to reboot and try again.
Once you have pressed a key, setup should begin. You will see a reference
asking if you need to load special drivers and another notice that if you
wish to begin the ASR (Automatic Recovery Console) depress F2. Just let
setup run past all of that. It will continue to load files and drivers.
Then it will bring you to a screen. Eventually, you will come to a screen
with the option to (1) setup Windows or (2) Repair Windows Installation
using the Recovery console. ***The selection you want at this screen is
"Setup Windows,"
NOT "Repair Windows Installation.
The first option, to setup Windows is the one you want and requires you to
press enter. When asked, press F8 to accept the end user agreement. Setup
will then search for previous versions of Windows. Upon finding your
version, it will ask if you wish to Repair your current installation or
install fresh. Press R, that will run a repair installation. From there
on, follow the screens.
If you only have a recovery CD, your options are quite limited. You can
either purchase a retail version of XP will allow you to perform the above
among other tools and options it has or you can run your system recovery
routine with the Recovery CD which will likely wipe your drive, deleting all
files but will restore your setup to factory fresh condition.
If that doesn't resolve it, if you have another available partition on your
hard drive, you might try installing XP to that drive and then copying your
data files from the old setup to the new one. If you don't have an
available partition you could use third party software such as Partition
Magic, www.powerquest.com, to reduce the size of the current partition in
order to create enough free space in which to create a new partition.
If you do this, you will likely receive an access denied message when trying
to access your data files. If this occurs, take ownership of the files as
follows:
Note, file ownership and permissions supersede administrator rights. How
you resolve it depends upon which version of XP you are running.
XP-Home
Unfortunately, XP Home using NTFS is essentially hard wired for "Simple File
Sharing" at system level.
However, you can set XP Home permissions in Safe Mode. Reboot, and start
hitting F8, a menu should eventually appear and one of the
options is Safe Mode. Select it. Note, it will ask for the administrator's
password. This is not your administrator account, rather it is the
machine's administrator account for which users are asked to create a
password during setup.
If you created no such password, when requested, leave blank and press
enter.
Open Explorer, go to Tools and Folder Options, on the view tab, scroll to
the bottom of the list, if it shows "Enable Simple File Sharing" deselect it
and click apply and ok. If it shows nothing or won't let you make a change,
move on to the next step.
Navigate to the files, right click, select properties, go to the Security
tab, click advanced, go to the Owner tab and select the user that was logged
on when you were refused permission to access the files. Click apply and
ok. Close the properties box, reopen it, click add and type in the name of
the user you just enabled. If you wish to set ownership for everything in
the folder, at the bottom of the Owner tab is the following selection:
"Replace owner on subcontainers and objects," select it as well.
Once complete, you should be able to do what you wish with these files when
you log back on as that user.
XP-Pro
If you have XP Pro, temporarily change the limited account to
administrative. First, go to Windows Explorer, go to Tools, select Folder
Options, go to the View tab and be sure "Use Simple File Sharing" is not
selected. If it is, deselect it and click apply and ok.
If you wish everything in a specific folder to be accessible to a user,
right click the folder, select properties, go to the Security tab, click
Advanced, go to the Owner tab,
select the user you wish to have access, at the bottom of the box, you
should see a check box for "Replace owner on subcontainers and objects,"
place a check in the box and click apply and ok.
The user should now be able to perform necessary functions on files in the
folder even as a limited account. If not, make it an admin account again,
right click the folder, select Properties, go to the Security tab and be
sure the user is listed in the user list. If not, click add and type the
user name in the appropriate box, be sure the user has all the necessary
permissions checked in the permission list below the user list, click apply
and ok.
That should do it and allow whatever access you desire for that folder even
in a limited account.
Posted on Oct 27, 2008
Cannot boot from cd rom
check out cd/dvd-writer.if any dust partikels clean with caned air.
Apr 22, 2013 | HP Compaq Evo D310 PC Desktop
My ACER Aspire 4736Z cd-rom drive is not working. It doesn't read/write, it's not even showing on My Computer. On the device manager there's an exclamation mark (!) and a Code 10. Please h
The driver for that cd Rom is not loaded or is corrupt. You need to install a correct device driver. If it still doesn't work try reloading the os.
Dec 26, 2012 | Computers & Internet
Dvd/cd writer will not recognize cd's or blank disk's will recognize dvd but not play.
Did this problem occur after a OS upgrade? Open Device Manager, DVD/CD-ROM drives, open and uninstall the DVD/CD rom. Reboot your machine, Win 7 should apply the correct driver. If you need a driver go to your manufacturer's website. Drivers and support section.
Dec 14, 2012 | Computers & Internet
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
HP d220m will not boot from hard drive, have tried several but nothing happens.
Hello, can it be your cd or cd rom that is the problem? I sugggest that you try with a other cd rom and make a copy of your cd and try to install from the new one. Plz post your exact error here.
Apr 05, 2012 | HP Compaq d220M (829160054797) PC Desktop
HP dv6745 cd/dvd rom drive isn't recognized in dev. manger but is in my Bios
hi
take your OS CD , insert into CD bay-- when prompted to , select REPAIR
this will correct any corrupted registry errors that my be found in your OS, which is causing the lack of recognition for the CDROM driver
good luck
Jan 03, 2012 | HP Pavilion DV6745US Notebook
I have toshiba tablet without a cd-rom and want to farmat the system and it is useing xp windos os but even when i using an external cd-rom it load the os what do i do?
Before the computer boots press Del key constantly then the Bios screen appears in that change the first boot device priority to CD Rom then exit the Bios by saving the changes. This should help you in recognizing your OS disk...
Sep 15, 2010 | Toshiba Computers & Internet
Bios not recognizing hard drive and cd rom. usb ports work
Hey I have the same problem, may have found a solution to this problem although im not 100% positive but read My post here in a reply to the same exact problem. Keep in touch with Me on this and maybe we can find a permanent solution
Feb 16, 2010 | Acer Aspire 5050-3371 Notebook
When i turn my computer an error displayed on the screen "No Bootable CD in ATAPI CD-ROM
Enter into the BIOS and check the boot up order devices.
Must be HDD-0 first and CDROM second.
Is the harddrive recognized in the BIOS
If you don't know how to enter the BIOS let me know you computer brand and model so I can guide you.
Jan 20, 2009 | Computers & Internet
Unable to detect cdrom on nec laptop
You need to check if it is a specific disc isssue or driver error or if it is the actual cdrom drive that is not functioning correctly. Please go to device managers and see if your cd rom drive is working correctly, then post back.
Feb 14, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
761 people viewed this question
Alun Cox
