Question about Panasonic KX-T7453 Corded Phone
Auto attendant issue d1232 & a KX-T7453
When calling in from the outside and receiving the auto attendant there is a particular extention (224) that if you spell by name or just dial it the system comes back and says "Sorry no one is available to answer the call...." (it does give you the option to press 1 and leave a VM message which does work and you do hear the recorded personal greeting)
The extention can be dialed normally from another extention... if you dial it with the FWD light on the phone flashing the call will go directly to VM. If you dial it with the FWD button off the extention will ring.
I checked the management settings in the VM system, its not set to forward all calls and that would result in it going to voicemail anyway which its not.
Why can't I get to it from the auto attendant? I've tried to cancel everything I could think of...
P.S.
extention 224 does have a greeting recorded...
cnavarro
  • 2460 Answers
SOURCE: D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Posted on Sep 19, 2008
cnavarro
  • 2460 Answers
SOURCE: KX t7453 Voicemail not picking up
Try dialing 710x 165 (#) from the intercom on your phone, where x=2 for all calls, 3 for busy 4 for no answer and 5 for no answer/busy. Once you dial it, the FWD light should blink and if you press it again it will go out.
You probably just canceled the original setting.
Carl
Posted on Oct 31, 2008
cnavarro
  • 2460 Answers
SOURCE: Can't find how to set my voicemail message on Panasonic KX-T7431
Thanks for all the helpful information! First of all, I think you have a TVS/TVM voice mail system. That's good, but what does the lady say when you dial 265 or 165 from either your phone or a phone that works?
If you have voice mail set up, the prompt would be to "Enter your password then #" or "You have X new messages" if you don't have your password set. If you don't get ANY of those on your phone, but do on someone else's, you don't have a mailbox.
Mailboxes are added from the System Owner's mailbox (999) by
option 6 then 1. Once you have a mailbox, you do use option 5 and 3 or 2 or 1 for Name, Password, and Greeting.
Since there is little difference between the models of voice mail, I have attached a TVS-50 manual. The instructions for adding a mailbox start on page 280 (or use the System Manager's Guide tab on the left).
http://public.carl.airpost.net/TVS/TVS-IM.pdf
With any luck, you'll get voicemail too :-)
Carl
Posted on May 14, 2009
  • 1456 Answers
SOURCE: Call forwarding kx - t7433 problem. Hi guys, hope
Hi
You should look for a call forwarding code in your manual.
Contact your landline service provider if you are unable to find the forwarding code and a customer service representative should be able to walk you through the process.
Pick up your phone receiver and listen for a dial tone. Enter the forwarding code on your home phone. Most of the codes will begin or end with the * (star) or # (pound) logo for pulse type phones. Rotary phones will typically require a numerical sequence.
Enter your cell phone's number, including your area code first. Wait for the confirming sequence after you have dialed in your mobile phone number. This will let you know that call forwarding is activated.
Dial the deactivation code when you want to turn off call forwarding to your cell phone. Your mobile phone will continue to receive calls if you don't turn off the forwarding option. Enter your landline service provider's specified code to cancel call forwarding.
Posted on Oct 02, 2010
ThePoodleGuy
  • 24 Answers
SOURCE: I have a Panasonic KX-TGA652 dual handset no
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Posted on Nov 21, 2010
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
How many stations can a Panasonic D1232 support?
If it says D1232 on the box, it's a TD-1232. Look at the black and silver tag on the side of the KSU, IIRC the TD-1232's tag is on the lower right outside above the power cord. Three is a TA-1232 a TD-1232, and a 123210/11. Only the TD is digital (uses 72xx/74xx phones).
As far as SYSTEM phones, the TA/TD 1232 come out of the box as 8x16 devices and you add cards to expand it. These cards have -70 part numbers and are fairly difficult to find. (I think I have one or two on my shelf). If you really have a 123211, it also expands by using cards, that fit vertically in the card file with an AMP connector plugged into its face. Those are easier to find, the risk there is when you turn off the system to install them, it sometimes forgets to power back up.
Lastly, if you really have a TD with digital phones, there is an ANALOG port on the back of each digital phone that can be wired for seperate extensions (by default it's 100 more than the digital extension). You can add single line devices in those ports.(Some restrictions apply :-). For two quick phones, you might go that route.
Carl
Feb 28, 2009 | Panasonic KX-T7453 Corded Phone
I can't make a call more then 6 digits on our PBX D1232 pls help
You obviously need to change the system programming to allow you to dial more than 6 digits. If you are not the system administrator, then talk to him/her.
Feb 24, 2009 | Panasonic KX-T7453 Corded Phone
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
Auto attendant
No. It is possible to set it up on the system. A call to your dealer would be the most logical step.
Carl
Jul 22, 2008 | Panasonic KX-T7453 Corded Phone
Programing
Try the instructions on the Panasonic Website. http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Super-Hybrid-Phones/model.KX-T7453.H
Jul 08, 2008 | Panasonic KX-T7453 Corded Phone
7453 Display
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Jul 07, 2008 | Panasonic KX-T7453 Corded Phone
Expanding phone system
We have existing Ativa Model # D5772 & just purchased a 2nd model How do we connect the 2 systems?
Dec 12, 2007 | Panasonic KX-T7453 Corded Phone
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
96 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
