Question about Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Nerf vulcan internals
My nerf vulcan ebf 25's belt feeder and plunger system recently jammed and wouldnt fire. i took it apart to fix, and now i have the internals laid out with no memory of how they fit together. anyone got instructions or pictures of the internals?
2 Suggested Answers
  • 7 Answers
SOURCE: my son has taken apart
Below is a internal picture of the stampede.
Contact me at mohammad7597@hotmail.com
Posted on Jan 08, 2011
Once the plug is on the bolt (Fig 3 in instuctions) is there anyway to get it off again??
rcdodge posted the same problem on Aug 15, 2011. I've just posted a solution aginst his question, so try that (it's a bit tricky though).
Oct 25, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
I put my battery pack in backwords and i cant get it back out
Can you try wedging something in there to use as a lever, like a screw driver or a butter knife?
Mar 14, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
I just got my new nerf stampede and put batteries in. I turn it on it fires 4 darts and then just stops. there is no sign of jamming
There are multiple factors in the inconsistency of your product's functioning.
1.) You have not successfully screwed in the battery cartridge tight enough so as the metal conductors are touching (with pressure).
2.) Your batteries are dead or almost dead.
3.) You put 4 bullets in your clip - kidding :)
4.) The circuitry may not be high quality, was your gun tampered with or from an unreliable source?
5.) Your jam door may not be high quality and could often slip from its locking point, I'd suggest taping it momentarily to keep pressure on it just to see if this is the case.
6.) The clip may be loosely in also, I'd also look into that.
If your gun stopped working permanently- I'd suggest looking inside at the white plunger, and the parts that release it from its pressurized position. There are many diagrams on the internet of the internals for it.
Email me a dluzzio@gmail.com for more info.
Feb 10, 2011 | Hasbro Nerf N-Strike Stampede ECS Blaster
Stampede ECS won't fire the darts. It sounds as if it is firing, however, the darts just stay in the chamber. The spring mechanism is moving and the batteries are new.
I had this same problem. Well, actually after I modded it. I hope you are good with your hands, because this takes effort.
Unscrew the casing and open the gun (remember to take the battery pack out and have the two plates together so that the wire connecting them doesn't break).
When you see the plating covering the plunger (spring) system take it off, it has about 5 screws.
Since this is extrememly hard to explain in words, look at an internet picture of the internal plunger system. The way it works is that when the spring/tube goes forward (as the motor operates) the 'plunder' (the white thing) stays back. As the orange tube goes forward it triggers and release mechanism that fires the plunger forward due to spring pressure, compressing the air, therefore firing the bullet.
All you have to do (which is what I did) is insert a clip (with the plates open), make sure the jam door is closed, and put the battery pack in (to complete the circuit). Do a bunch of test runs to make sure the white plunger is shooting forward as the mechanism operates.
This will all make sense once you activate the gun without base plates.
Email me at dluzzio@gmail.com if you complete it, have questions and/or comments.
I hope it helped!
PS- while you're at it, you might as well look for online instructions on how to mod the air restrictor (as I am too lazy to write a few more paragraphs!).
Jan 02, 2011 | Hasbro Nerf N-Strike Stampede ECS Blaster
HELP!!! My nerf gun maverick is broken.? when i shoot it the bullet fires about 10 feet only. when I took it apart nothhing seems to be wrong. Please help me fix it by telling me what to do.
I had the same problem too. Try opening it up and looking at some online pictures and compare them, if you still cant find the problem and you have the receipt, take the unit back where you got it from. Look at the springs really closely my maverick was broken due to a spring that slid out of its elevated piece of plastic. I fixed it lubricated some parts and put it back to together. It works great now. :)
Dec 21, 2010 | Nerf Maverick Blaster
Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Jan 04, 2010 | Nerf Toys
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Nerf Vulcan Jammed Belt
Have you tried opening the top latch? I know it locks with the chain in place but I am able to get mine open with some applied force. Also is the belt wedged? the belt can be pulled through with out harming the gearing. I have been trying to find more out about jamming solutions on the web and these suggestions are the only things I've read about. If this doesn't help perhaps Nerfhaven.com where hardcore Nerfers can tell you more.
Mar 15, 2009 | Toys
Hasbro Nerf N-Strike Vulcan EBF-25 Blaster Logo
141 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
