Question about Exercise & Fitness
Any help with error code 12 with pacemaster pro elite?
4 Suggested Answers
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
  • 1796 Answers
SOURCE: Where is the elevation fuse on a Pacemaster Gold
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
Pacemaster pro elite INCLINE MOTOR DOES NOT WORK
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Exercise & Fitness
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
I have a PaceMaster Pro treadmill. I'm getting a dead sensor error message. Where is the RPM sensor on this treadmill? And how do you replace it?
It would be easier to help if I knew the exact model of the treadmill. Here is a link to what a speed sensor looks like.
http://www.treadmilldoctor.com/speed-sensor
You will most likely have to remove the cover on the bottom part of your treadmill to see it.
Aug 17, 2014 | Exercise & Fitness
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
ERROR CODE 30 ON MY PACEMASTER PRO PLUS
DescriptionErrors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.Proceed according and fix it. God bless you
Mar 23, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Pacemaster pro plus error code 20
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
Dec 24, 2012 | Exercise & Fitness
Looking for a user manual for a pacemaster proplus treadmill
I have a pdf of the Owners Manual for a PaceMaster Pro-Plus Treadmill. I am attempting to upload it to www.manualsonline.com, so if you still want it, hopefully they will have it soon.
May 08, 2012 | Exercise & Fitness
Exercise & Fitness Logo
93 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
