Question about Yamaha DVR-S120 DVD Player
All DVD`s installed in player skip .Also DVD`s that showed title donot now.
My DVD surround sound player started skipping with it`s own rythum thought it was the DVD I was watching tryed other DVD`s with same result. Also noticed the title of move was missing from moves that showed title on player in the passed.took player apart used dustoff to clean there was no visable dust Installed disk with player cover off watched the player start counter (no title) also I had no TV in work shop then went to menu I pushed play and watched counter 1 2 3 5 6 7 10 and so on .Skipping I also watched laser eye scroll back and forth in 1/16th movements all so have had no power surges PS I am a fire alarm panel tec for simplex grinnell programable systems so I have experience looking at boards there is no visable damage hope you can help me with my problem thankyou .
  • Anonymous Jun 20, 2008
    problerm as stated in previous fault
    President:
  • 4,402 Answers
First thing i would do i clean the lens with 90% isoprople alcohol and a q-tip, if that doesn't work watch the laser eye again and the movement is the laser look like it tries to catch up???
i would put a dc volt meter on the motor and the motor should stay at lower voltage if it climbs then there is something with the rails or worm gear. let me know what you find out.
Posted on Jan 04, 2008
My iView 2000hd DVD player does not read any DVDs that I put in it. It scans it for about a minute then comes back saying that there is no disc. It tried a couple DVDs, making sure that it wasn't any...
hi there.
DVD Player Disc Not Reading Repair Tips. DVD players use an intricate laser device to scan the surface of the DVD. ... When a message appears that there is nodisc in the player when there is, it indicates a problem with the disc, the laser, or the loading mechanism.31 Mar 2015
DVD Player Disc Not Reading Repair Tips ' Techwalla.com
https://www.techwalla.com/articles/dvd-player-disc-not-reading-repair-tips
How do you clean a DVD player at home?To maintain your DVD player, occasionally unscrew the player's case, so you can get at the lens to clean it. You need a screwdriver, canned air or a soft brush, a foam swab or camera-lens cleaner, and lens cleaning fluid from a camera store. Here's what to do: Remove the top cover screws.How to Maintain Your DVD Player - dummieswww.dummies.com/home-garden/home.../how-to-maintain-your-dvd-player/Search for: How do you clean a DVD player at home?
Why does a DVD player skip?One of the most common problems that occurs with DVDs and DVD players isskipping. ... The same thing occurs when a DVD skips only it messes up the picture and can cause you to miss whole sections of a movie. An excess of dirt, grime, dust, and even fingerprints can damage discs and contribute to skipping.31 Mar 2015How to Fix a DVD Player That Skips ' Techwalla.comhttps://www.techwalla.com/articles/how-to-fix-a-dvd-player-that-skipsSearch for: Why does a DVD player skip?
if you go to this link it will show what a laser disc cleaner looks like and where to buy one from.
DVD laser disc cleaner Google Search
Nov 21, 2017 | Televison & Video
Just hooked up an fiber optical cable(digital optical) for my bose surround cinimate2 sound to my ps3 to the bose reciever, Now i get good sound, but when i play a dvd it skips and pauses, is it the ps3?...
gosnell6960
Most likely the default format of the video that you are playing is not supported buy your receiver. You may try to go into the audio setup and switch it to another format and/or try a disk that supports other audio formats to see if you still have the problem. They any are always coming out with newer versions of dolby and dts. So some times the new version is not fully compatible with the older receivers.
Let me know i you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
Sounds skips when playing DVD
I THINK THE DVD IS SCRATCHED OR TRY TO INSTALL
THIS SOFTWARE VLC MEDIA PLAYER
http://www.videolan.org/mirror-geo.php?file=vlc/0.9.8a/win32/vlc-0.9.8a-win32.exe
Dec 09, 2008 | Intervideo WinDVD 4 Plus (WDVBF-7663-40RC)
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Screen keeps skipping
if it is progressive scan, one of three cables or inputs may not be functioning.
Jan 14, 2008 | Cyberhome CH-DVD 300 DVD Player
Movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Jan 04, 2008 | Sony DAV-S500 System
All dvds skips evan brand new ones
Return the unit to the store which you purchased it from. You have an internal problem with the scanner (led) You can first try to clean the led this could be your problem. They sell lens cleaning dvd disks. try it, you have nothing to loose. If this does not work, just bring it back.
Dec 27, 2007 | Coby 5.1 Channel DVD Player with Home...
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Yamaha DVR-S120 DVD Player Logo
120 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
