Question about Toro Garden
Repair Manual - Toro Snowblower CCR 3000 GTS 5.0
Need specific instructions on removing engine cover for carburator repair or replacement.
SOURCE: i have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Posted on Mar 24, 2009
SOURCE: toro 521 snowblower..nn replace gas line to carb,
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
Posted on Dec 31, 2009
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
odiebugs
  • 949 Answers
SOURCE: Hello, I have a Toro snowblower Model ccr 2450.
Remove the starter, then check the teeth, if the teeth
are ok, then the throwout Bering is bad, this is the part than pushes out the teeth so it contacts the
flywheel. The parts you need, teeth ,spring, throwout,
show as a kit, but you must buy them from a toro dealer, You need to have your serial #, because the parts are listed by different serial #'s. Now most times you would have to buy the whole starter, but it looks like you can get the kit. If the teeth are bad then the throwout is ok, but you still need the kit to fix your problem.
Posted on Feb 14, 2010
SOURCE: toro snowblower wont start.I have a toro ccr
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Posted on Oct 22, 2011
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
Hello, I have a Toro snowblower Model ccr 2450. The starter runs but does not engage to start the engine. Can you tell me how to fix this problem without taking it to a repair shop?
Feb 14, 2010 | Garden
I have a toro ccr 2450 snowblower. i bought it
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,038 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
