Question about Fisher and Paykel Dishwashers
Fisher paykel dw681 light blinking 7 times
The green LED on my dfusher paykel dw681 is blinking seven times. It starts the wash cycle if you press reset, but then drops back to rinse and the LED starts blinking again. Maybe 1 out of 10 times it will actually complete a full cycle. I had another fault recently where it blinked four times. After a bit of fiddling I found the pressure sensor to be full of grease, and after cleaning, the machine worked OK for a couple of weeks, but now has this new error.
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Posted on May 09, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
Fisher paykel GWL10 doesn't drain Previous problem
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Sep 26, 2013 | Washing Machines
My old Fisher and Paykel GW711 washing machine worked fine until I moved house. It worked fine a few times here, too. But now it fills, but then doesn't start the wash cycle, then after about an hour, it...
sounds like an electronic problem. motor controller most likely. I am unsure off hand what this fault (7) means, but the number is very low, which normally indicates motor control board
Sep 12, 2013 | Fisher and Paykel Washing Machines
Fisher and Pakel WL26CW1 code 246
i would say its one of the boards usually the main motorcontroller
Jan 11, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
116 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
