Question about RCA F27628 27" TV
Red screen My t.v. works fine except for the fact that the screen is red. I can still see the picture and it does apear that blue kinda shows up very slightly. I took the cover off and they have a troubleshooting guide but Not really sure what to do. I have tried changing the number settings on the color bias and drivers to no effect. Is it worth fixing or should I just buy a new set.
    Novelist:
    Champion:
  • 275 Answers
Christ, why did you disturb the bias settings? Which stupid @#$% told you to that? The red color was most likely a blown Red Output Transistor, or something as simple as a bad CRT base. Now, I suggest that you switch off the TV, wait for a couple of hours, open the set, and very slowly and carefully pull the CRT PCB (along with sockets base. Then clean the CRT terminals (use a fine emery sheet.) Also check the base for dry (cold) solders. Replace the CRT board. Picture should be normal. If problem persits, then it is definitely the Red Output Transistor or associated components. Get a professional to have a look.
Posted on Aug 23, 2006
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
All inputs work except for the component videos.
When your tv shows a blue screen it not getting a signal!! In your mit's you have to go into the customer menu and turn on the input/device. The device control is on the remote, click over to input and activate (enter). Also, look into owners manual, the customer service at mit's will step you through it if you wish. Note: put cables into comp 1 (eg), make sure colored cables are correctly inserted, and audio. (red, blue, green) red/white; audio.
Apr 02, 2008 | Mitsubishi WS-55311 55" Rear Projection...
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Rolling screen
them dang old dust mites... but seriously blue and red means you lost your green. the rolling means also your vetical sync is gone ....perhaps you hit a setup button ...take a good look and see if a button pushed in or sticking around where you dusted.to unstick you need a service man.
Aug 31, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Blue Crt? or Lamp?
what most people do is a simple one a white pice of card and simply phocus your blue,green and red on the board...till they show if blue fails to illuminate then a shop maybe the answer as you dont want to start messin around if you dont what you are doing,,,
Aug 10, 2007 | Panasonic PT-51HX41 51" Rear Projection...
RCA F27628 27" TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
