Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
How to change head gasket on mclean lawn mower
3 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: just replaced head gasket, now has to much compression
A head gasket will not greatly increase the compression in a a Briggs motor.
My question is Why did it need a head gasket to begin with?
Will bet it was not running...
A more likely cause if not a fuel problem is to check engine oil if that is good remove the wire from the low oil sensor and see it it will start up for you.
r/
David
Posted on Jan 23, 2010
Try checking the lash on your valves if it has overhead valves
Posted on Jul 08, 2012
12AEB2JZ701 what is the compersion to be
I think you had a question on the compression on a lawn mower? I repair them from time to time and would not recommend repairing a lawn mower below 55 lbs. psi. I really try only to wonk on lawn mowers with 65 lbs. psi or better. Sometime you can help the compression if you tighten the spark plug or top head bolt but you have to be careful not to tighten them too much. Usually when you have low compression you either have wear on the piston rings or leak on the flat head gasket. Usually if you have over head valves if there is a small leak it can be repaired with silicone gasket material. I hope that answers your question. MJ
Jun 20, 2016 | Garden
HOW DO I PUT HEAD GASKETS IN MY 178 JD LAWN MOWER
Well, first of all, do you need to replace the head gaskets? Can you give me more info? Is this on a rider, what size engine and brand. What is your level of expertise? If you have a blown head gasket, you need to figure our what or why did this happen.
This should be relatively easy, once you remove all shrouds, then remove the head bolts, the the head will come off, replace the gasket, or gaskets if a twin, and torque the headbolts in a star pattern. Depending on the size of the engine will determine your torque settings.
Feb 19, 2015 | Garden
Unjam mower starter cord
If you mean that you cannot pull the engine over then remove your spark plug and try with plug out. If it turns over with no plug in then you probably have a carboned up head. Remove head and carbon and reinstall head with a new head gasket.
Oct 06, 2014 | Toro Power Lawn Mower
Mower run 4 or 5 minute start smoking what is the problem
Thanks for posting your question and I will do my best to provide an accurate answer.
The symptoms you describe lead me to believe that you have a defective head gasket on one or two of you cylinders. The head gaskets fail between the valve pushrod area through which oil passes to lubricate the valves and the cylinder bore. this allows oil to pass into the combustion chamber causing the oil to burn and cause the smoking.
It is not uncommon and is a relatively inexpensive repair. The head gaskets cost around 20 dollars and the labor to remove the engine shrouds, carburetion, intake manifold, exhaust system to access the cylinder head should be three to four hours. It is very wise to replace both head gaskets since the labor to change the other is 1/2 hour or so vs. three or four again if the other fails a short time later.
I hope this answers your question.
Kevin
Jul 12, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 20 hp B&S Craftsman Intek egine. It is burning oil (smoking). his is only the second season for this mower and I mow only a small lawn takes about 1 hr. I changed the oil religiously. The...
i would say it is the head gasket , there is only a little space between the valve train and the piston, and this is where the gasket lets go, when the piston goes down on intake or power it sucks the oil past the gasket then out the exaust valve
Aug 15, 2011 | Parks Optical 13.5hp Briggs And Stratton...
Have a toro recycler white smoke continuous after starting
This is not a good sign!! You have blown a head gasket, the rings around the piston have gone bad, or you have blown a hole in the piston.The head gasket isn't so serious, and it may be worth fixing. However, the other two scenarios are serious and wouldn't be worth fixing if the mower is old.
Good Luck!
Jim
Aug 05, 2011 | Toro Power Lawn Mower
I have a mountfield sp470 petrol self proppelled lawn mower. the engine is briggs& stratton but i dont know the engine model. i need this as the cylinder head gasket has gone and needs replacing.
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Sep 12, 2010 | Garden
Just replaced head gasket, now has to much compression and won`t wind over fast enough to start. have had starter checked and seems ok .10.5 hp briggs and stratton motor in a murray 32 inch ride on lawn...
r/
David
Jan 23, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
How does gas get into your oil pan on a lawn mower
The gas float could be sticking in the Carburator. Gas will go down the intake, into the piston, down the cylinder walls and into the oil.
Jul 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
16 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
