Question about Hoover Vacuums
How do i replace a cam actuator spring on a hoover c1413-930
How replace hoover windtunnel self actuator arm
Hello! We recommend taking your vacuum in to a Hoover authorized service center to have the self actuator arm repaired or replaced. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Jul 04, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
Its a bit tricky but with some patience you can replace it. I have linked a video that I think will be helpful.
Jun 15, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Take the handle off, then remove the tool holder, then you can get to the switch. Just has tabs on each side of switch, depress them and push it out. These switches will do this after awhile, replacing them is usually the way to correct the problem.
Dec 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I HAVE A HOOVER STEAM CLEANER MODEL#F5881-900 THE SOAP LEVER HAS NO TENTION,SOMETHING BROKE BUT DONT KNOW WHAT!
The valve at the bottom of the tank has a valve stem and spring, you may have to replace the spring maybe.
Go to http://vacuumsuperstore.com/F5880.html for a picture.
Jul 13, 2008 | Hoover Vacuums
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Brushes won't spin anymore.
I left you with a solution and picture diagram in the premium solutions, did you get it?
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Valve actuator, arm & spring assembly
Could not find a picture of this installed, I have replaced this spring and it is hard to do. You have to put the straight prong of the spring unto the valve arm, you will see a spot for it to be at, then wind the other end of the spring around until it goes into a slot, then get it all together on the agi housing before it comes apart. Hope this makes sense.
Feb 15, 2008 | Hoover U6660-900 WindTunnel Bagless...
Vacuums Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
