Question about Toshiba 50H72 50" Rear Projection Television
Red & Blue lines on screen
Hello ,
I have a Toshiba 50H72, it has bold red and blue lines,I've been told about the convergence I.C.'s and also that I could repair myself, and was looking for a schematic and part number the two (2) I.C.'s for:
Toshiba Television
Model # - 50H72
Serial # - 10623482
Chassis # - TAC 0262
MFG - June 03
Any help would really be appreciated.
Best Regards,
Phil Gamboa
  • 1 more comment
  • papagamboa Oct 27, 2008
    Thanks for your quick response, do you happen to know if a schematic comes with the replacement I.C's or where I can get one?
  • papagamboa Nov 02, 2008
    Thank you!!!
  • Anonymous Feb 18, 2009
    tosihba television 50H72
    i have the same model and chassis # but the last 4 serial digits are are different it was manufactured feb 03.
    I'm experiencing the same problem; im seeing a second picture as a shadow with red blue green effects in the picture as well. what can i do to stop or fix this?
    Problem Solver:
  • 5 Answers
Stk392-110 i think mine was made in 2002 and i also had to replace mine
Posted on Oct 27, 2008
Toshiba 50h72 has red and blue lines through it
that could be a convergence problem or the hyper module.
Jan 28, 2010 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 have blue and yellow ghosts
Sounds like your convergence circuit went out. It lines up the red,green and blue picture tubes so the colors are lined up. Usually these TVs all use the same type of IC chips called "STKs" both usually get replaced along with any resistors etc.. around these chips that may have burned up. Depending on who fixes it could be around $300-400 parts and labor.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Toshiba 50H72 50" Rear Projection...
Blue light (RGB) will not converge (Toshiba 50H72)
Look around the area of the STKs and you should see some low valued resistors. One lead of which will be attached to the STKs. One or more of these is open. Replace it/them and you should be fine. These are current limiting resistors (effectively fuses) for the power to the STKs. One of them is not getting power.
Dan
Jan 23, 2009 | Toshiba 43H70 43" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72 picture and sounds takes 20 min to warm up
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Sep 09, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50HX70 Convergence reset
You will need to replace the convergence ICs. You can order them at this link and they provide free support as well as installation instructions with pics so you can do the repairs yourself. You will need to replace both convergence ICs
http://servicemanuals.vstore.ca/
Mar 30, 2008 | Toshiba 50H72 50" Rear Projection...
50H72
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2008 | Toshiba 50H72 50" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Trouble with the red cannon
Hello, is the blue blur the only blue on the screen? The reason I ask is because the vertical defection to the blue CRT might be going bad and producing a blue line across the screen. I doubt that it is a convergence problem, but it may also be a magnetism problem and you may need to degauss your set with a degaussing coil (check ebay for specials on this device). I have seen a lot of the projection TVs end up needing to be demagnetized (degaussed). Try degaussing it first and then look at the possibility of a vertical deflection problem and then possibly a convergence issue.
Sep 26, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
