Looking for remote codes for vizio sound bar and time Warner cable remote
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
SOURCE: olevia 432 s12 remote codes for time warner
These are the codes for Olevia if you have a Time Warner Remote 1144, 1240, 1331 or 1610
Posted on Jun 18, 2008
VOTIT
  • 2071 Answers
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 02, 2008
SOURCE: My Time Warner cable Remote will not program to my TV.
I had the same problem, so I followed these steps and it worked!
1) Turn on TV.
2) On the remote control, press TV once (it will blink once). Then press and hold SETUP until the TV key blinks twice.
3) Enter 9 9 1, (the TV key will blink twice).
4) Aim the remote control at the TV & press POWER once.
5) Press & release the CH+ key continously (you may need to press it more than 50 times!), then stop when the TV turns off.
6) Press POWER. The TV should turn on, then immediately, press SETUP to lock in the code.
Posted on Aug 22, 2009
  • 29 Answers
SOURCE: Time Warner codes for remote set up
Timer Warner Remote code for Vizio TVs: 1758 1756 0864 0885 1499.
11756 10864 10885
Posted on Dec 12, 2009
Use my vizio smart remote for time warner cable
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 03, 2014 | Vizio XRT110 Remote Control 0980-0306-0940
Vizio soundbar remote code for TIME WARNER
If it is not in the manual for the soundbar, There is no possible way to get it to work, Unless it mentions auto search in the manual,
Dec 02, 2012 | Vizio Vsb211 - Home Theater Sound Bar...
Need 3 digit code for vizio vsb200 audio bar for a clikr-5 UR5U-8780L-TWM remote
There is no listed 3 digit code. You will have to do a code search. Press and hold the Ok and Aux button for 3 seconds. You will have to press the CH+ or CH- (does not matter which) for upwards of 400 times but the code is in there somewhere between 290 and higher, I lost count. Here are two tips. Move the cable box out of site of the remote and expect the TV to turn off when it hits its code. This will make you think you have found the code as the sound will go off. Don't fall for it. Look at the light on the sound bar only. Once the TV turns off you will need to have it;s remote handy to turn it back on so you will hear the sound again.
Once you pass 290 or so go slow and don't miss the light going out on the sound bar or you will have to do it all over again.
Once you turn the sound bar off press the AUX button again to lock in the code.
It's a pain but the code for Vizio sound bars is in there, don't let them tell you it's not. Took me about 7 tries to find the sequence and make the mistakes but my Vizio bar is now Programmed to the Cliker-5 and works fine. Good Luck.
May 19, 2011 | Televison & Video
Need a code for the Samsung Sound Bar model HW-C450 with the Time Warner CLIKR-5 remote model URSU-8780L-TWK
I need the codes for my samsung sound bar system using timewarner remote in san diego.
Dec 24, 2010 | Televison & Video
I am looking for the code for my Visio Sound Bar to program into my Dish Network remote to the AUX button. Has anyone talked with Visio Support to get this code? Thanks.
ronwright22
I have provided a link for you to Vizio's Website. The information below is for a VSB210WS sound bar. I would go to this link and research your model number and look for the code. You may try the code on this screen to see if it will work. I have also provided a link with instructions on programming your DISH remote to other components.
Vizio Website:
http://www.vizio.com/vsb210ws.html
This is the VSB210WS sound bar.
Programming a Universal Remote to operate the HD Sound Bar System If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program a device button with code 31517. This will map the Universal Remote button to operate the HD Sound Bar System as follows: Pictured at right is the VIZIO VUR8P Universal Learning remote.
Ray Calo
DISH Network
Nov 09, 2010 | DISH Network IR Remote Control
11756 10864 10885
Dec 09, 2009 | Vizio L32 32 in. LCD HDTV
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Televison & Video Logo
3,553 people viewed this question
Top Televison & Video Experts
Electro Med Services...
