Question about Garden
Gas coming out of the muffler for lawn mower - Garden
  • 109 Answers
SOURCE: lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 246 Answers
SOURCE: when i start my mower gas seems to come out of
Hello
IS the Crankcase Oil Over Filled and have a Gas Smell to it?
If Yes, then the Carburetor Float Needle Valve is Not Seating Correctly and is Flooding the Engine when the Engine is Not Running or the Head Gasket is Blown Between the Push Tube Galley and the Cylinder.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
vincob
  • 718 Answers
SOURCE: my lawn boy 6.5hp mower isblowing fuel out of the muffler
Maybe it's a stuck float valve or a bad float. Had a similar problem on a TORO rider but that turned out to have a pin hole in the brass float, it filled up with gas and let just about the hole tank through the muffler. I changed the brass float and still running to this day! Note: your float may not be brass if it is a newer machine it will be plastic.
Posted on Oct 01, 2009
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Replacing the muffler on the poulan pro 550 model number 961240002 00
there is two ways to mount mufflers on small engines. one with two bolts through the muffler to the block or threaded to it. if you don't see bolt heads then you unscrew the whole muffler.
Aug 06, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
Jul 06, 2012 | Parks Optical 13.5hp Briggs And Stratton...
Gas leaking from muffler
Blown engine. Replace engine.
Jun 17, 2012 | Toro Power Lawn Mower
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Blue/white smoke from muffler, but when muffler is removed smoke disappears
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
Aug 03, 2009 | Briggs & Stratton Garden
Lawn mower blowing out white smoke
Apr 05, 2009 | Garden
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
