Question about Samsung TV Remote Control
SAMSUNG AK59-00124A
My remote seems to work fine when i look at it true a digital camera(mobile phone) When i look at the blueray player true the camera while pressing the remote, a blue spot appears on the front panel. BUT nothing happens! ? When i press a button on the front panel the player respond, but not while pressing the remote control. What could be wrong??
  • 9 Answers
SOURCE: Which is te code for the AK59-00104L Blue ray
I've found that you can use a Synergy V Universal Remote which is supplied by some cable companies like Time Warner, RCN etc. You can also buy this remote. Code 576 worked on this remote. I can power up and down, rewind, FF, and I can launch Netflix etc usinf the ABCD keys. You can't control everything but this remote does a good job of controlling all my different components including my LG TV, Bose Sound and Cable Box.
This pdf seems to be best reference.
Posted on Nov 28, 2010
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: Samsung remote control problem
Same issue as lisawrob
Check to see if there is another remote with something sitting on top of it. I had the same problem and found another remote transmitting (continously).
Posted on Aug 10, 2008
  • 1297 Answers
SOURCE: i accidently pressed the reset button on samsung 27s7 remote
To delete the codes which have been entered in the remote unit press and hold down the SET key and then press the 0 key for more than 4 sec.If the LED will flash twice the codes saved in the remote is arwe deleted.
For rewiev the factory settings please remove and reinstall the battery.
Posted on Sep 02, 2009
SOURCE: original ak59-00104r remote control device does
Take the batteries off, press the button "0" for 1 minute, put the batteries back on, try it out.
Posted on Mar 19, 2011
I need Samsung TV remote control code for setting up Sony Blueray Player remote control.
0279,0277,2870,2851. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 16, 2014 | Samsung Televison & Video
Can't work out how to eject DVD from my sony blueray player
Use that button infront of a mobile camera, if you see light then the remote is ok.
you may try to disconnect the dvd mains and reconnect and try.
Mar 06, 2014 | Sony Bdp-s780 Blu-ray Disc Dvd 3d 1080p...
Panasonic blueray dvd player mo remote cannot watch movie is there a solution
I take it you have no remote? or your remote isn't working?
If you have no remote you can get them online or through hardware stores for your model player, failing that many programmable multi remotes are available that will give you most functions. If local stores fail Check ebay!
As for controlling it without a remote i would need to know the bluray player model number. but if you have the manual and the player has a USB socket check to see if a standard USB keyboard/mouse is compatible.
Another alternative; if you have it connected to a home network there are mobile phone aps to let you control it.
Jan 04, 2013 | Televison & Video
I bought a new samsung tv and blue ray player. The blue ray player was a display so it did not come with any manuals. It only came with the remote and the blue ray player. I cannot get the remote to work...
If the Samsung TV remote will not operate a Samsung Blueray player, I would say there is something wrong with the Blueray player then, Otherwise if you need a downloadable manual go to the following website and enter the model number you have. i hope that helps : )
http://www.samsung.com/us/support/
Aug 01, 2011 | Samsung Televison & Video
Just received a Samsung BR BD-P1500 2009 model, as a gift. No one code for the remote control work for my Panasonic Viera TC-L37D2 bought in 2010. Samsung "assistance" told me that my BR is too...
Unfortunately, Samsung tech support was accurate. Most universal remotes (and the portion of the remote programming to control other devices is the same program) only have codes for devices released 6 months or more before the remote was programmed.
However, any universal remote that is newer than the TV (by that 6 month programming period) should control both devices. Low end universal remotes may not support all of the features of either the TV or the Blu-ray player. The remotes that can be programmed via a USB connection to a computer are the fastest to set up. (Alternatives: You can use both remotes when watching a movie or get a Viera link Blu-ray player that is compatible with the TV. For the second option, you need a device with the HDAVI Control (not above Control 5) connected via a good HDMI cable)
I wish that I had better news.
May 08, 2011 | Samsung BD-P1590 Blu-Ray Player
I currently bought a tasco 3mp game camera at walmart works fine in the daylight but flash isn't working am I DOING SOMETHING WRONG OR IS IT A DEFECT
I, too, recently purchased this camera. The Chinese got us this time. My flash works, but it seems like nothing else does. I'm a scientist. I got if figured out. And, what I figure, is this trail cam is a piece of ****. Nothing on the packing is remotely true of the camera.
Sep 01, 2010 | Cameras
My Sony BDP-BX1 Blue Ray remote stopped working. I have replaced the batteries several times, but it does not work.
Check whether the remote is sending a signal by using a digital camera, still or video. While looking at the LCD screen of the camera, point it at the remote which someone else is pushing buttons on. If you see the (infrared) diode flashing on the remote, you know it's working and there is a problem in the BlueRay player.
If there's no flashing, the most common problem with remotes is the timing crystal inside breaking free of the circuit board, or maybe just a cracked solder joint to the crystal. Get someone who can solder to take the remote apart and check for this possibility.
Apr 18, 2010 | Sony Televison & Video
Comcast DVR remote won't work the volume on my Samsung tv
Have you dropped it by accident from a high height or on hard surface? Have you spilled any liquid to it?
Doesn't all the button's seems to work?
Here's a one trick if you have a mobile phone with camera:
enable camera on your mobile phone. Look for a WORKING remote control from the other electronic stuff at your house. Point your remote control to camera lenses and press any button. Do you see blinking red light on your mobile screen? Try this with your DVR's remote control and see if it works. If you are sure about the polarity of the batteries and checked that they are new enough, ther's only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Feb 14, 2009 | Jensen TS2050J 20" TV
New flatscreen/remote not working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Samsung TV Remote Control Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
