Question about OKI Office Equipment & Supplies
Fuser failures on the okidata b6300. Printer gives 310 reboot error and sometimes the printer has a low page count. Is there a fix for the fuser or do you just have to replace it, Thanks for your time, Ken
Yes u need to replace it plus u need to cleen the heads.
that is how I fixed mine
Posted on Oct 26, 2008
Replaced fuser on Dell 5110cn printer. How do I reset?
There is no way to reset the Dell 5110 fuser 310-8729 (also known as TD218 and other numbers)
The connector in the fuser holds the page count. If you printed 200 pages on a fuser and moved it to another printer, you'd see it follow the fuser.
You may have put a non-compatible fuser, or it may be depleted already, or there is a circuit board problem.
Whit
Item, Inc.
Sep 17, 2010 | Dell 5110cn Laser Printer
CHANGE PAPER TRAY DRAW
Do you often face technical problems for Okidata printers? Just contact our experts Okidata Customer Service at 1-866-877-0191 for best assistance. Free online tech services are available 24*7 at toll free number. For more info, visit: http://printertechnicalhelp.com/okidata-printer-technicalhelp.html
okidata printer 18668770191 customer service-aizo5avvrofwceza0ykjsgo4-1-0.jpg
May 03, 2010 | OKI B6300 Laser Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | OKI B6300 Laser Printer
Fuser error on the hp 3700dn printer
You need to replace the fuser since it is most likely caused by a bad fuser. The 50.1 error indicates a low fuser temperature which can be caused by a fuser failure or a DC controller failure. The HP part number for the fuser is Q3655-69001 for a 120V printer. You can also get the fuser as a replacement supply from your toner supplier the item number is Q3655A. Depending on how long you have owned your printer, the fuser needs to be replaced at 50 months or 75,000 pages which ever comes first.
Apr 13, 2009 | Office Equipment & Supplies
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
Okidata c5200n printer 173:FATAL ERROR. What is this? How do I fix it?
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Mar 11, 2009 | OKI C5200n Laser Printer
How to solve "reboot printer (010-349)error in OKI B6300 printer
This is a fuser disconnection error. Try to remove the fuser and put it back securing properly in its place.
Jan 20, 2009 | OKI B6300n Printer
OKI B6300 error message: Please reboot printer (010-349)
Detect Fuser Trouble. Replace fuser if power off and on cannot recover the fail.
Aug 15, 2008 | Office Equipment & Supplies
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
710 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
