Question about Ovens
Whirlpool model rf302bxkw oven won't shut off
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Posted on Jun 09, 2011
KevinWhite
  • 1902 Answers
SOURCE: stove reads F3 and won't
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 15, 2011
Daniel S
  • 4323 Answers
SOURCE: Whirlpool electric oven model RBS305PDQ12
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 01, 2011
  • 389 Answers
SOURCE: whirlpool oven won't heat after power outage
you will have to press the hand on your timer it needs to be set back on manual its on time cook you will hear it click back and your oven light will come on and heat read how to in the book that came with your oven
Posted on Nov 06, 2011
ginko
  • 19396 Answers
SOURCE: Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Posted on Dec 13, 2011
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
Hi.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Oven won't shut off
Here is a tip that I wrote about why an electric oven will not shut off.
Electric Oven Problem Oven will not shut off
heatman101
Sep 28, 2011 | Amana AOCS3040 Electric Single Oven
I have a whirlpool stove that is gas the display won t work so cannot use oven.
It's likely that the board on which the display is found also contains the control electronics for the oven functions.
If you want to look into replacing this yourself, go to the link below for illustrations of your unit but the page lists several variations beyond the model number you listed so check your literature from your unit to establish which exact unit you have:
Whirlpool range
Sep 16, 2011 | Whirlpool SB160PEE Gas Single Oven
RS696RXBQ2 - won't heat up, get error message F3 then shuts off.
This tip i wrote explains what the F3 error codes means and what to check to fix your oven.
http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 12, 2011 | Whirlpool Ovens
I'm following the instructions on my Whirlpool range to clean the oven. I've done everything the instructions said, but it won't get going. ( set the knob to clean, set start and stop knobs...
Might be a typo in the manual typically the latch is moved to the right to close and after clean is over move to the left to open. BE SURE TO REMOVE RACKS BEFORE CLEANING
Aug 11, 2011 | Whirlpool Ovens
GE jvm140k prchase 1993. Oven timer works and displays time and progaming but oven won't start up. It has been working off and on but now won't work at all.
The model you gave was for a microwave oven. In the backside of the microwave is a air cooling window. If it gets clogged with junk the mag will overheat and the limit on the side of it will shut down the oven. Simply cleaning this area so that air can circulate better can cure the problem. I suspect it finally got so bad that the cavity thermal limit has blown now and you have nothing at all.
I have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 27, 2011 | Ovens
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
