Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LQ1 machine stuck in control lock mode
I know there must be a simple solution... how do I escape from the control lock setting?
    President:
  • Whirlpool Master
  • 2,651 Answers
Sure is,look to the far right buttons one says hold to lock/unlock the controls. hold it for 3 secs and your good!
Posted on Oct 26, 2008
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: GHW9100LQ1 machine stuck in control lock mode
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Posted on Oct 27, 2008
Control locked is on. How do i reset this mode ?
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Washer is stuck in "control locked mode" and won't start. It's normally in door locked mode. Whirlpool duet
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. .
Jul 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stuck in safe mode. error code 01. please help
This is what is called a mem lock-up and to escape you need to press reset, though you will need to set up the clock etc again.
Jun 15, 2010 | JVC GR-D270 Mini DV Digital Camcorder
My washer control is stuck control lock
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front loader he 4t. how do unlock the control panel it is loack mode! red light is on & I can not do anything to get it unlocked!
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
Nov 13, 2009 | Washing Machines
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Apr 21, 2009 | Whirlpool Washing Machines
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GO-Video model DVR440 (DVD/VCR combo) Child Lock ON, No response to POWER button
can only be done by remote control unless you have the complete manual to reset all your saved settings from the front panel
Mar 31, 2008 | Televison & Video
GO Video ? DVR440 (VCR/DVD) Combo
The only other thing I can think of is to unplug the machine for 5 minutes and see if the machine defaults to the factory settings...accordianman
Mar 29, 2008 | Televison & Video
Whirlpool Duet GHW9150P Front Load Washer Logo
199 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
